  • Replies 198
Ok i have an idea...
1) How About we meet at roma at 8:30pm. Done!
2) Seems everyone, me included, is keen for a MAD MTN cruise... Dave is up from wednesday apparently.. So why dont we do the run this sat night? Could get some great pics at night... :)
Whats everyone think?
mmm mabey leave the mad mtn to its own, but there was a cruise from springwood to hinze dam a few weeks back by boostcruising, apparently the route was pretty decent, went up through tamborine ect, and then once we hit hinze cause it will probably be closed at that time of night, just head straight across the dam and on to bwcp or shell mudgeerabab or bermuda st
if ya interested i can try and get the cruise course
ok this is copy and paste from the boostcruising/xibit cruise, one of the guys who was on the last sau cruise "gry-32" will know it too cause he was on it, i actually didnt cruise this one, seing as hinze dam is just up the road i just drove round when they all got there :)
the directions seem to be pretty detailed and on the money, ill check em all on my refidex and see how that goes, and ill make any changes to it if need be
Take exit 34 * Beenleigh North *. Right at Logan st lights .
Straight though the first roundabout then right at the next following the mount tambourine signs.
18k: Stop at 7’11 servo for regroup and for people that forgot to bring food! If you go down the LEFT of the servo past the car wash there is a big car park where we can stop n chat and so forth while people buy food and etc. were only stopping 40mins at the MAX ;P play it by ear me thinks, continue the way we were traveling after we leave trying to keep together
31k: You will come across two “1 lane” bridges . WARNING. They are 1 lane please give way to other motorists . This stretch of road is also a little bumpy but I’m not afraid to take the 180 down it and I guess Ill be the lowest car there. The road stays bumpy for 5km’s. Take it easy and you shouldn’t have any problems.
39k: Left turn onto Tambourine Mt rd
3pm
43k Beginning of climb! – could the slower cars please pull over to let the AWD and 4WS cars past.
48k WARNING very narrow pass. Caution recommended
50k Follow the road left thru the village round to the left
53k REGROUP after the mountain I think we would have needed a regroup spot this is just after the look out area . there is a parking sign you cant miss it .
55k right turn down white road
58k very steep decent, also there are traffic signals to let people down the mountain in packs because its 1 way. You will know what I mean . just be wary of this
60k military training area ! : þ – DO NOT LEAVE YOUR CAR. It is a live ammunition area.
62k one way section give way
64k left at the gold coast sign
73 right clagirrba rd
75k nasty crest. Take it slow fear of getting air bourn!
5:00pm
79k right at murwillumbah
83k left Heinz dam
lol, can an admin change my retarded date giving in the post headline! i just thought friday hmmmm thats the 28th, add one = 29th lmao!
That course sounds pretty full on, would be great fun at night... I will be taking it easy, anyone who takes it hard will be on the edge of their seats i think!
yer, i went and cruised the esplinade thisarve, if i get bored again ill head up and do that run, see what its like, i think ive done it once before when i was in year 12, but that was a while back and we were er, well we didnt really know precisly where we were headed :)
ok well i have run the course from beenleigh north exit to hinze dam and its a pretty decent cruise, plenty of widing stuff, a bit of straight stuff, some down hill stuff, and some down hill winding stuff(read tight hairpins)
id say the group will end up bein split in 2, but if we use the regroup points that are along the way should be fine, i also suggest yas take note of the crest towards the end, i comes up pretty suddenly :D
i have the path mapped out and if need be i can photo copy the pages of the refidex for whoever is gonna lead, ill be sitting in the middle with the sedate group :) most of the bends are well marked so it should be a good run
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
