I can't believe what i am reading. When my fuel gauge reads 1/4 i hit the pumps. This is to avoid any sh1t in the tank from being sucked through and blocking filters, injectors, etc. Also prevents the engine running lean when cornering hard. Just remember Australia was one of the worst supplies of fuel in the world. I have read that farmers in europe wouldn't use our grade of fuel in their tractors, due to it's impurities.
I'm the same. It gets to a 1/4, i find me a BP.
But hey...i like to treat my GTR well :P starving it would be mean :P
  • 1 month later...
