Ok I know this is a fair bit in advance but would be good to see who would be interested going next yearand make it a fixed day. I dropped in this years and as a car enthusiust must say it was fantastic, with well over 1,500 cars of all Marquees there it was a great show. It is set for all car clubs to get together and have a Picnic/BBQ with other club and display their pride & joy cost per car was $12 so you could have 3-4 people in the car at that cost. there are food tents. drinks & food vans for the ones that dont want to bring anything. A penny for your thoughts...
https://www.sau.com.au/forums/topic/10918-picnic-at-hanging-rock-feb9-2003/
Hanging rock is near Mt. Macidon (spelling?), about half hour past Calder Park raceway.
I have been every year, for the past few years and it is great.
I would love to see a whole group of us making a presance. But i will be in two minds whether to put my car with my club display or with you guys and girls. Maybe we can organise the two clubs to be side-by-side, then i am in a win win situation :D
Unfortunately my car was in the workshop on that day :)
Originally posted by R31Heaven
loooong looong time ago
hehe ..... someone else who's been watching too much TV.
The movie "Picnic at Hanging Rock" is based on a 1967 novel by Joan Leslie. (It's fiction!!!!)
Example........
Look at this webpage, Picnic at Hanging Rock
Valentines day in 1900 wasn't a Saturday, it was actually a Wednesday :)
Sorry John, I'm done, you can have your thread back now. :D
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
