For anyone else stupid enough to try this, the GTST kingpins don't fit either. You'll need 40022-60U05
Yeah I have, but the pricing is a little bit too high, think it was like $750 AUD. It's just a sucky thing to find, I think at this point I'm just going to have to wait for someone who is wrecking one.
By WHITEBEAST · Posted
Found one for $2650 in Sydney to replace this mess 🤘. -
R33 GTST rear bearing works the same way as the GTR one - but it's not the same part. You have to get the correct GTST one. You can see the difference between RWD and AWD bearings on this page https://justjap.com/search?q=r33 rear wheel bearing
I'm not 100% sure for a R33 GTST but could check with a VIN#....however in r32 gtr it is a separate bearing which bolts in at the rear (front is separate press in). *to be clear* the bearing bolts to the hub but you still need to press in the stub axle with the wheel studs to the bearing
