hey all
My new stagea has a problem.
My new car pics&details
the car is automatic, and today when i was driving it, it stalled on me two or three times. was travelling at walking speeds in a car park and the check engine light would come on then the car would stall seconds after. I think i sore the O2 sensor light come on but im not 100% sure because by the time i looked down car had stalled and was in accessories mode. the car will restart with no worries at all.
anyone have any clue to what this is?
https://www.sau.com.au/forums/topic/109193-my-new-stagea-stalls/
Dont mention it...you'll soon learn that we're a helpful bunch around here.
You'll receive advice that you just cant pay for.
Waz
P.S. Dont wash your engine, or you'll have more then stalling problems
yeah hey i had the same problem with mine not so long ago i checked all vacuum lines and no leak i then started checking everything it turned out to be the O2 sensor. hope you can get it fixed soon cause it is a bitch when it happens especially if your going around a round about and u got nothing the steering is heavy as hell
what was wrong with the sensor? is it the sensor in the dump/front pipe or the one in the cat?
It's in the the front/dump pipe. Visible from the top of the motor. Like most electrical stuff, they usually either work or they dont. I've never had to replace one, so others here may be able to shed more light. But basically, it simply unscrews and you whack in a new one. Prolly best if you spray the thread with WD40 or similar to loosen the rust. If possible borrow a friends as this could turn out to be an expensive and pointless exercise if the original is OK. Still, they're not that dear - under $100. Check that the voltage outputs on the replacement 0r borrowed one are the same as the original.
