I noticed that when the oil temp is relatively low, like 85 degrees and under, it can boost to 0.7km/cm.
However when the car is driven for say 25mins and more, the oil temp gets to 92degrees (day or night doesnt matter) and usually stays at that point.
When it gets to 92degrees, the boost level cant get past 0.6 kg/cm. Please note that I am reading all this out of my stock GTT boost gauge
Why is this? Because of all the heat in the engine bay, does the SMIC intercooler suffer from heat soak? and so cant boost as high? However, I can drive for say 15 minutes without hitting boost (some time for the intercooler to cool) and then when I do hit boost, it still only gets to 0.6.
1) Is it the SMIC? and is it supposed to cool down when driven without thrashing?
2) Is my factory boost gauge reading wrong perhaps as the car gets really warm?
Edited by nuffsaid
Forget about the oil temps guys.
Thrashed it at 80 degrees, same boost level.
Engine bay is quite hot, I guess thats normal for these cars. I have removed the turbo heat shield though since I've installed a dump pipe.
Would this affect it?
Ill try giving it a hit in the morning, I bet it will get to about 0.7kg/cm.
Get a decent aftermarket boost gauge, the standard map sensor is engine bay temp sensitive.
:) cheers :O
I gave it a hit this morning, it made it to 0.7km/cm.
So perhaps the MAP sensor isnt reading fully right. Is it bad to remove the exhaust manifold heat shield?
Unfortunately the exhaust workshop who fitted my dump pipe has my heat shield (which he probably threw away), he recommended taking it off because it can cause rattling sounds if it touches the dump pipe. He has installed heaps of dump pipes and says that its normal to leave it off.
Edited by nuffsaid
  • 3 weeks later...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
