james, i did this with my car.
what i did was go to bbc and get 2 light l brackets, theyre like 35 cents each.
screw one side of the bracket into the top of the vent where you cant see it so the other side hangs down. then screw the plate in.
70 cents and works just as well as anything from japan :)
i'll try and get you some pics
Sweet, I look forward to seing pics of the different brackets that you guys are using ... the $0.70 job sounds like the plan, got a bunnings just down from my place on Parra Road. Just gotta figure out where to secure the brackets.
Tony, as far as defects go, I was under the impression that when it came to mounting, the plate must be visable front the front of the vehicle and could not be obstructed by glass (so not behind the windscreen) but it didn't have to be in the perfect center, just visable from the front of the vehicle.
Were you advised of any particular reason as to why having your number plate mounted on the side is deemed a defect ?
Does anyone have the ADR in regards to this ?
Oh this cop was a kuntbag.
He says that only cars that came out of the factory with the offset plate is non defectable like the Alfa 156.
Mine just had thin bent metal straps that bolted to the bottom of the bar opening.
I use white slimlines now so it doesn't impact on my FMIC.
T.
Went through booze bus on Thursday - cop actually said it looked good (he had a GTS-T). Victoria may not be as strict?
James: Will take detailed photo in the am and will find shipping cost of Cusco mount from JapanParts.
Here is front shot of car.
You can see the aluminium bracket above the 'GT' part of the plate. It secures to a bolt (just 1) in that position. I backed it with gaff tape so the numberplate screws don't scratch the paint :D
Is very light aluminium and came with a cool Cusco sticker :)
Very cool little part... but the DIY approach will achieve the same result and be much cheaper.
Dude... i thought i PMed u instructions alreaDy! hhahaha
one word.............
'L' SHAPED BRACKETS !!!
L shaped brackets (1.5mm stainless steel) are available to help make a corner
joint with your front bar AND using a phillips screwdriver with (2) screws, attach the number plates together facing upright. If u are creative, u might use a washer behind the screws. ;)
i don't see why it would be illegal to have ur number plates on one particular side of the car provided that it is still visible. Most Audi and other euro cars have front no. plates on side as factory position.
Thanks Miz, got some L shape brackets tonight from Bunnings ... inflation is a bitch $1.20 each !!! :D
Here's the info I have received on offset mounting for anyone interested.
It isn't an ADR restriction. There are angles of visibility requirements (cop writing parking ticket needs to be able to read the front plate, cameras need to read rear plate) and the rear one has to be lit (with complying lights) but they are allowed to be centred, left or right so long as they are properly upright (fairly close to vertical) and visible at the appropriate angles. As long as it's not recessed, it should be fine.
Oh, and in response to things such as the Alfa's with offset mounts, they have a specific ADR apparantly to do so, which is why I wanted to investigate this further. Apparantly the plate must be level and not follow the contour of the bar, however I believe in the case of the 156 it actually follows the bar which is why it required the ADR.
I looked on the vicroads site and found nothing, but i seem to recall that offset plates were illegal in Victoria.
They changed the law recently so you can actually get fined $220 and 3 points for having a dirty or obscured number plate here in VIC. Whether that would fall within their definitions I'm not sure. Its all due to revenue raising and city link cameras being designed dumb so they change the laws to suit.
as far as i know it's not illegal in vic to side mount you number plate.
As long as it's on the LEFT had side (if looking at the front of the car) so it can be seen by on coming traffic etc. it's fine.
Right had side is illegal though in VIC so ya can't do that.
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
