I'd question the dealer about that one..... There should be a green plate =under the bonnet somewhere and a silver VIN number affixed to the firewall next to the original japanese VIN number (usually on the lip at the back)
If a car is not complianced then it has been bought in illegally and if caught the Govt has the right to make you crush your car and then send the evidence report to DOTARS.....
Go see the dealer and ask to see the RTA inspection report, Import Approval, and invoice.... they might not show you the invoice but the other one's should be no problem...I hope)
Cheers
Loz
i got vin number but no compliance plate. and i have renewed my rego last year with no problem at all. unfortunately, the dealer i bought the car from has sold their business to other company and although they are still using the same company name, but they are different owner. i tried to call them today but seems they don't want to know anything about this.
what a load of rubbish!
Your car could be a rebodied vehice....pm me the vin...i might be able to tell you from that what the story is...i wouldnt panic
could be a test and evaluation vehicle thats the only way.. but after 12 months they must have a compliance plate fitted otherwise big fine. Been through this with a dodgy company already in Vic who somehow wanted to escape their obligation of fitting the compliance plate after 12 months. you wil be able to renew rego but when it comes to selling - good luck... IS it in Vic, otherwise its be done illegally as ylwgtr says.
re bodied cars is ghosting, and that is illegal....
I posted the stuff about DOTARS ..ice 180, Ylwgtr seems to think what i said was crap....:argue:
But it is what i read about when i was researching skyline's before i bought one...
I heard there was a big crack down on imports in Vic due to the company being found out...
I'd get in contact with DOTARS and have a chat to them about the situation and see if they can offer some advice on what to to....
Loz
Loz
Err , not completely true.
Rebodied cars is not ghosting if the damaged vehicle and new body has been presented to the relevant authorities.
It is done with Commodores and Falcons all the time by a company here in W Aust ( Carrera Autos )
It is illegal to remove the chassis number from one car and insert it in another.
equinoz , I wouldn't get too worried , if was bought and lic thru a legit car dealer , there is usually an explanation.
I assume you are talking about your R33 and not some older car right ??
Cheers
Ken
sounds liek complete bullshit in vic it is impossible to get car regoed without compliance plate unless t&e vehicle althoguh with recent events that might not be true. Was it from the country I have heard of some people paying off local staff to look the other way. Not sure how it works in NSW but thought similiar to Vic.
forogt to put it on HTF did he get it regoed then?
A re bodied car would still need the (a) complaince plate... wouldnt it?
to show that it meets australian standards and is legit right.... because the chassis numbers would not match..... that's what's throwing me off here.
I'm unsure whether Imports and Aussie car's come under the same rule... with re bodieing....
Whats the lowdown boyz?
i've checked with RTA today and all my registration is legit, car is registered, nothing wrong, and when i asked him about the missing compliance plate, he said that's fine as long as your car is registered. but i think i need that bloody compliance plate if i want to sell my car right?
SELLING AN IMPORTED VEHICLE
If you have followed the procedures outlined in this brochure and the vehicle has met the requirements for import approval and initial registration, there is no restriction
under the Act preventing the subsequent sale of an imported vehicle unless conditions have been applied to the Approval.
Check with the Registration Authority in your State or Territory for requirements regarding the sale of an imported vehicle. Addresses are at the end of this document. It is an offence to supply to the market (ie to sell for use on a public road) a vehicle that does not meet the ADRs, or is not fitted with a compliance plate, identification plate, used import plate or Personal Import plate and such action may attract a penalty of up 120 penalty points per vehicle. 1 penalty point equals A$ 110 (as at 22/ 1/ 02).
Vehicles 15 years or older shall not be fitted with a compliance plate under the Act. You should consult your State or Territory Registering Authority for registration requirements for these vehicles.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
