Thanks guys.....If the spots dont get filled then yes it gets cancelled.
If it gets cancelled you will all recieve a full refund, however it shouldnt be the case, i have a fair few people looking into paying this week so it should be ok.
Regards,
Dean
  • Replies 66
Regards,
Dean
sweet
also as you make know SAU had problems due to cancellations of wet weather and all, have WSID mentioned any penalties etc?
just to make sure WSID doesnt do the dodgey and keep the deposit.
Hi Guys, some of you have asked questions such as can bikes race etc. Here are the answers.
Additional Information
1) Motor bikes CAN race, however they are not permitted to race against cars. Same rules apply with a bike, they cannot run faster then 11.00.
2) Gates and scrutineering starts at 8am, racing at 10.
I am still in discussions as to what happens if the day is a wash out (rain). I will update you guys as soon as i know (should be tomorrow)
Dean, I would be very careful in any dealings with WSID due to what has happened to SAU NSW at its last private drag day. Is there a contract or written agreement with WSID? What happens if veryone turns up and thn it rains: (a) before racing starts and before track is prepped; (b) before racing starts and after track is prepped; © after racing starts.
I am not personally worried about it, just don't want to see the club holding the event to be in a similar situation that SAU NSW was in whereby the WSID management were going to keepa substantial amount of money which meant that each racer would lose about half their money.
I am still keen Dean however have committed to other track days prior to this one which have chewed up my spare cash.... i will be sure to keep in touch and should there become spots availiable in the not to distant future will be sure to tranfer funds as soon as possible....
I understand your concerns guys, at this stage nothing is written as no money has been transfered. Everything has been verbal at this point.
I have some info however i am waiting on a confirmation call from WSID tomorrow to get the final details.....at which point i will post them up.
PS, i am keeping record of who i speak to, what number i called them on, date, time etc so there shouldnt be any issues, but ill see if i can get something written before money gets transfered across to them.
Ah ok, i am assuming you may have put your name down to the V8owner track day.
Ok, let me know how you go, if your still interested and there are still spots we can sort something out for you.
I have actually decided to try my hand at turning corners.... and not just the corner at the end of the drag strip :( UAS is holding a circuit day at Oran Park on the 2nd of April so, providing the 200 is tuned, i will be heading out to try my hand at circuit racing....
We should be able to come across some cash for this day but obviously am not going to over commit myself just yet... Will let you know the minute i know more
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
