  • Replies 87
Hey Abo Bob,
Thanks for your e-mail, i appreciate your input.
Just one question:
Between 2k-5krpm how much timing are you running?
You also mentioned an issue with porting, but the example you used related to an rb26. I personally would not touch the head of a 26, as they were engineered for race purposes, apart from port/manifold matching as stated. The rb25 on the other hand is totally different and i still believe gains are had from porting, provided it is done by a profesional porter.
I run stock R33 S1, rb25det, compession. (i think it is 8.5:1 or 9:1??????)
adam also runs an auto which may (or may not) affect dyno readings and spool up related to manuals (effect of torque converter vs no torque converter).
Have you got head work too Bris?
..only when i was dropped in the hospital, and when i fell from the 3rd floor verandah...oh and the time when my brother hit me in the head with a 3 iron...:P
I wouldnt bother with headwork unless your head is off the car. New gaskets, plus the head reco to go along with the porting...too much money.
Now I'm interested.
Al. Fark you and your bloody head porting. You too SK. I thought I'd been able to get the modification bug out of my system. Now I want head porting. You both suck. ;)
;) Couldn't stop laughing when i read this, GOLD. :angry::rofl:
DO IT!!! You know you want to..... :woot:
You saw my results with a shitty tune, imagine a tune like yours on my engine set-up, it would be awesome.
After porting the next step would be bolting up a GT-RS ;), GREAT response with equal power. :wave:
Bris is right though; If you remove your head it is best to reco it. The only thing mine needed (it was more a preventative measure) was valve stem seals, the set cost about $330.00.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
