25 to life Posted March 12, 2006 Share Posted March 12, 2006 i am interested in using an RB26 in my next build up in circuit racing. but to be honest i have no experience with the motor. i just want to know how much HP can the stock internals hold.?????? what can it be bored out to? block quality?? thick cylender walls?? stock red line?? red line with good rods, rod bolts, rods exetra, also how much can the man. tranny hold??( are there two diff. available. one RWD and one for the AWD set up, who makes the tranny). so you know i usually shoot for around 700 rwhp with great response that can handle the 8000-9000 rpm range. hate to seem like a dummy. but i just want to get a plan together. i have look all over forums and on the web but cant find this simple info. can i get those rates in US specs? please dont hate me cuz i am from the us. if it makes you feel better my familys from down south as well. the south pacific. Tonga. i also have a lot of fam in Australia. i am just messing around now, i know you guys dont care about that. but back on the subject. thanks for any info given on said engine and tranny. s/t more, whats up with the rear end, diff, cv joints. etc.??? strong?? weak points to consider???? Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/ Share on other sites More sharing options...
Duncan Posted March 12, 2006 Share Posted March 12, 2006 what sort of power are you looking to run? which turbos? At up to say 250-300kw and 8500rpm standard internals work fine if you build the motor properly. More than that and you start needing some changes Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2013028 Share on other sites More sharing options...
25 to life Posted March 12, 2006 Author Share Posted March 12, 2006 what sort of power are you looking to run? which turbos?At up to say 250-300kw and 8500rpm standard internals work fine if you build the motor properly. More than that and you start needing some changes as stated i usually run 700 whp. what does 250-300 kw stand for in horse power Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2013695 Share on other sites More sharing options...
25 to life Posted March 12, 2006 Author Share Posted March 12, 2006 what sort of power are you looking to run? which turbos?At up to say 250-300kw and 8500rpm standard internals work fine if you build the motor properly. More than that and you start needing some changes are there better years or block numbers than other years??????? or other advantages over others??? Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2013713 Share on other sites More sharing options...
ferni Posted March 13, 2006 Share Posted March 13, 2006 Don't think theres any difference between the block years. You can get an N1 block which is suppose to be a bit stronger. 1HP = .75KW to help you convert since we usually talk in KW here. so up to around 400rwhp on stock internals ( you can push more but it probably wont last long). 700rwhp is up over 500rwkw, thats bit power.... I think you'd be better going for a 3litre bottom end with an RB26 head and but it won't be easy. Good Luck. Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2013915 Share on other sites More sharing options...
Topaz Posted March 13, 2006 Share Posted March 13, 2006 Ant Scali is pulling 700+ (885hp top I think) with some serious internal mods including the 2.8L stroker kit, maybe consider that for extra power and rev range your after. From memory they retail around $6000 700hp = 522kW Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2014409 Share on other sites More sharing options...
R31Nismoid Posted March 13, 2006 Share Posted March 13, 2006 6 grand for full HKS stroker kit? why on earth you need 500rwkw in a circuit car is beyond me. What setup do you currently have? Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2016357 Share on other sites More sharing options...
Topaz Posted March 13, 2006 Share Posted March 13, 2006 6 grand for full HKS stroker kit? Just checking Nengun... http://www.nengun.com/catalogue/product/836 between ~$6,500 and ~$10,400 delivered depending on the power your after that obviously doesn't include the install Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2016369 Share on other sites More sharing options...
R31Nismoid Posted March 13, 2006 Share Posted March 13, 2006 So saying 6k... when the kit required is the biggest of them all (over 10k in parts) probably isnt a decent example as its not 6k at all... its over 10k And also putting it in with the example of Ant's car which most certainly is not using the 6k kit either... over 10k i would imagine Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2016381 Share on other sites More sharing options...
Topaz Posted March 14, 2006 Share Posted March 14, 2006 Tis a very expensive task Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2018808 Share on other sites More sharing options...
ER3498GTT Posted March 14, 2006 Share Posted March 14, 2006 If the car is going to be used for circuit then usually tyres, suspension and brakes are the things people play with... Horespower in circuit racing...often too much of it is counter productive. Good torque, moderate power I'd be going for along with the right set up (tyres, suspension and brakes) Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2018859 Share on other sites More sharing options...
Duncan Posted March 14, 2006 Share Posted March 14, 2006 500kw in a race GTR eh? bigger than most drag cars? I'm sure it will be a real dream to drive. I think you will find the group A cars had under 400awkw What have you raced where you "shoot for 700rwhp?" Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2019472 Share on other sites More sharing options...
N1GTR Posted March 14, 2006 Share Posted March 14, 2006 Im pretty sure Group A was 447 kw, being 600 hp (at the engine) Link to comment https://www.sau.com.au/forums/topic/109304-rb26-what-can-it-handle/#findComment-2019622 Share on other sites More sharing options...
