Rb26 What Can It Handle?
i am interested in using an RB26 in my next build up in circuit racing. but to be honest i have no experience with the motor. i just want to know how much HP can the stock internals hold.?????? what can it be bored out to? block quality?? thick cylender walls?? stock red line?? red line with good rods, rod bolts, rods exetra, also how much can the man. tranny hold??( are there two diff. available. one RWD and one for the AWD set up, who makes the tranny). so you know i usually shoot for around 700 rwhp with great response that can handle the 8000-9000 rpm range.
hate to seem like a dummy. but i just want to get a plan together. i have look all over forums and on the web but cant find this simple info. can i get those rates in US specs? please dont hate me cuz i am from the us. if it makes you feel better my familys from down south as well. the south pacific. Tonga. i also have a lot of fam in Australia. i am just messing around now, i know you guys dont care about that.
but back on the subject. thanks for any info given on said engine and tranny.
s/t more, whats up with the rear end, diff, cv joints. etc.??? strong?? weak points to consider????
what sort of power are you looking to run? which turbos?
At up to say 250-300kw and 8500rpm standard internals work fine if you build the motor properly.
More than that and you start needing some changes
as stated i usually run 700 whp.
what does 250-300 kw stand for in horse power
are there better years or block numbers than other years??????? or other advantages over others???
Don't think theres any difference between the block years. You can get an N1 block which is suppose to be a bit stronger.
1HP = .75KW to help you convert since we usually talk in KW here.
so up to around 400rwhp on stock internals ( you can push more but it probably wont last long).
700rwhp is up over 500rwkw, thats bit power.... I think you'd be better going for a 3litre bottom end with an RB26 head and but it won't be easy. Good Luck.
Ant Scali is pulling 700+ (885hp top I think) with some serious internal mods including the 2.8L stroker kit, maybe consider that for extra power and rev range your after. From memory they retail around $6000
700hp = 522kW
So saying 6k... when the kit required is the biggest of them all (over 10k in parts) probably isnt a decent example as its not 6k at all... its over 10k
And also putting it in with the example of Ant's car which most certainly is not using the 6k kit either... over 10k i would imagine
If the car is going to be used for circuit then usually tyres, suspension and brakes are the things people play with...
Horespower in circuit racing...often too much of it is counter productive. Good torque, moderate power I'd be going for along with the right set up (tyres, suspension and brakes)
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
