Sorry mate but there is such a turbo. It was made as a bolt on turbo upgrade for the nissan rb20/25 engine hence why the turbo has a t3 flange.
Yes the gate and manifold are included, basically every thing you need to bolt it on to an rb20
Im on the Gold Coast so if anyone is interested in looking at the turbo in person feel free to pm me and we can organise a time.
Chris
Chris
Great, post a photo of the ID badge on the turbine front housing please :P
Great, post a photo of the ID badge on the turbine front housing please :cool:
There isnt an id badge on it, just a series of numbers. If you dont believe me, ring danny from jms as they had one for sale last year for $1800 by itself. Their picture of the turbo never had an id badge either. If you want a pic of the turbo pm me your email and i will send you pics. If your not interested in the kit then please dont waste my time though.
Thank you for confirming this turbo nemini90
Chris
Chris
I think you misunderstood, I am actually interested, provided you can show some pictures showing not only the turbos condition, but something that confirms the ACTUAL model of the turbine itself.
Maybe its an ancient turbo, or hey maybe my Trust master catalouge I have on my lap here is wrong
I will say again, Trust did not release a turbo called a "TD05/06" .
Im more than happy to be corrected, though I dont believe thats going to happen.
Not trying to cause a problem, but I am after a turbo kit for my RB20 and your kit sounds ok assuming that you can provide clarification on exactly what it is you are selling.
It sounds like you bought something that JMS referred to as a "TD05/06" - In which case i wouldnt go telling people that do know about Trust turbos that they are wrong when you are only repeating what JMS fed you.
As for trim details i cant confirm anything for sure. No doubt a trust agent could confim trims with the serial numbers on the turbo. There is a 10 on the inside of the exhaust housing which i assume would mean 10cm2 but as said before i cant confirm the trim. JMS sold the same turbo as a Trust TD05/06 470hp turbo as well as a jap performance part website which i can no longer find.
http://www.nengun.com/catalogue/category/26
If you look at the pic of the TD-06, the turbo looks the same as that. If you would like pics pm me your email and ill send you some pics. If you are live in SEQ i would prefer you to come and have a look at the kit in person as photos cant show the play in the turbo or in this cause the lack of play.
Chris
Chris
Thanks Chris, you know you can attach the images to your post?
/\/\ Exactly what i was thinking.
Maybe the turbo died one day and when the previous owner rebuilt it they hi-flowed it at the same time?? Just my guess....
Can u tell me how laggy this sucker is on the RB20?
Cheers
The turbo is as bought. It has never been blow and never rebuilt. The turbo hits boost at 2000rpm and full boost a bit over 4000rpm. Though it may seem laggy I had a std r32 intercooler, injectors, ecu and everything for that matter apart from turbo and exhaust. With a intercooler and ecu, I would expect the turbo to hit full boost in the 3rpm range.
Chris
The turbo can be bought brand new from advan in syd for $3000 and it is a td05/06 on a rb25 with pfc and std motor was on full boost buy 3200 there not laggy at all..
There we go boys and girls. Cheers nemini90
Chris
  • 1 year later...
    • Surely the cam timing is set to something stupid at low RPM?
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
