hey all,
Just wondering if any og you guys with the R33's are intrested or like the LCD screen in between the rpm and speedo gauges...
It was an option on the series 2 and it is very rare today to find or even get the part..(as so what ive been told)
Any you guys got any advice on it? problems.. where you guys sorced yours from?
i got mine through a importer which pulled it off a import and i happened to be there at the right time...so i grabbed it.
Cost me $1250... but i havnt seen many skylines with it and its pretty neat i rekon... :P
give us some of your opinions.. :D
https://www.sau.com.au/forums/topic/109329-r33-nismo-epson-lcd-cluster/
yeh i got a pick of it here... if this works..
Ok here are some of the things it has:
*Electronic speedo - remebers your exact top speed
*RPM rem meter
*acceleration and that kinda crap
*G-force and that shit etc
* and it has a few other options which you can stuff around with
the guy i got it off said you can run DVD through it... and or navigation etc
I have done heaps of searching for this option on the skyline.. and have not yet found one car that has it.
Its extremly rare
And to contol it you get a little remote about the size of a CD player remote... maybe a lil bigger and it can change and scroll down the menu etc etc.
Edited by Jezza1
would this work with a s1 gts?? If i could pick it up for under 300 i'd be pretty interested (via yahoo auctions i mean)
yes the dash will work in any model r33 (s1/s2/gtr) but finding one is rare (last time there was one for sale was about 3-4months ago and it sold for $200-$300)
and without the epson system the middle tv wont displace anything (you can uses it as a tv but thats about it)
do u mean only the epson system???
When i brough it i got everything included.. the cluster.. the screen.. the epson unit.. the controller and all wiring.. basically plug and play.. if you know how to do the wiring..
Was the $200-$300 price for everything or just the epson unit?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
