Does anyone have a quiet 3 in cat back on their 32's if so what are they my one is way too droney
There are plenty around. Just look for one with a two muffler setup, I had mine chopped out because it was much too quiet for my liking and does not drone much at all. If you have an auto though do a manual conversion and the should fix you problem. :P
yeah i might have to go the fujitsubo, and yeah its auto havnt got enough for a conversion. anyone got a quiet auto 3 in catback?
ive gotta 3.5 inch from the cat to another muffler, then a 4 inch from that muffler to the rear muffler, actually it doesnt have a cat at the moment, its been replaced with a pipe, and its suprisingly quiet!!!!
the brand is fujitsubo.
Jhonny cash is on the money! Excuse the pun. I got a complete custom job done that from the cat back had a hotdog and then a high quality rear stainless steel wound (not packed and yes there is a big difference) cannon muffler. This set up was hell droney, sounded awsome but way, way too loud and on decelleration from 2200 - 1800rpm my ear drums hurt and it gave me a massive headache just getting it home! Took it back and got the hotdog replaced with a side-by-side resonater (looks like a normal muffler only the exhaust flow goes straight through on one side and the other side has a steelwool packed chamber to absorb the excess exhaust gas expansion which is what causes the exhaust note out of your rear muffler)
Exhaust note for me is absolutely perfect, I have a full unrestricted exhaust that has a great note but dosen't intrude. It is to quiet for some of my friends but its exactly what i wanted and with it being the only current mod everyone comments on how well my car goes.
So rear cannon = $128
resonator = $90
piping and mounts = $180 = Cheap as chips with great results. You don't need an expensive name brand.
just to add, Full custom stainless steel exhaust with dual dump that joins after the elbow, 3.5 inch stainless steel biscuit cat with previous mentioned cat back all fitted close to the chassis to ensure no scraping and HPC coated all up =$1000 flat = :D
Edited by ellie
    • Would you ever vent this bonnet or will it be unnecessary?
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I dried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4     I did the other 5 in less time than I fluffed around with the first one. I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the casing. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I overcome one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
    • Even back in the day, some importers were renowned for bringing in crashed cars, giving them a quick touch up + respray and making them look mint
