does your side pipe have a flex piece, or slip joint? if not add one. we just had to do it to the race car. cracked the extractors 3 times :) now with slip joint we hope it's better.
Not interested is "seeing" the crack. Just would like to view the shape of the manifold and a small circle where the manifold usaully cracks.
A flexi pipe or slip joint pip sometimes helps, but are mainly required for east-west mounted engines.
Solution may be as simple as adding a couple of solid supports, from the face plate to the flange. This will release some of the load, of the turbo and pipe, off the manifold runners.
As Roy suggested, I see a lot of Skylines with the entire exhaust hanging off the turbo and the rear muffler. You really need to make sure there is a good solid mount at the gearbox bell housing and flexible mounts to the gearbox subframe and to the rear subframe.
If it has those and they are in good condition, then some reinforcement of the exhaust manifold may be required.
:) cheers :O
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
