  • Replies 95
Car comes back again tonight with mesh behind the holes in the front bar and the indicator lights put in.
I'll take pics tomorrow when it's still day light.
Goes in for the full tune up and dyno run in the morning!
I'll post the results up once I get in here to work tomorrow.
http://www.exedy.com.au/clutch/hyperMultiPlate.htm
Thats the clutch i'm getting except it's been slightly modified to handle things alot better.
Dan might come on sometime and explain the clutch.
But from what Dan just told me, the clutch in the skyline now is absolutely rooted and it wouldnt of even lasted another week.
Looks like a button?
looks pretty much like my single plate 5 puck unsprung organic button clutch but in a multiplate.
its on or its off, it shudders, its noisy, its an absolute bitch in traffic. its there to handle the torque my cars setup puts out you get used to it but why youd sign up for that unless you needed it is kinda beyond me.
otherwise my clutches end up like this
but seriously, it seems like overkill
Belgarion I believe it is multiplate, twin I think from memory, exedy don't make a single plate clutch in a multi format.....
But good analysis of how it will be to use!!!
Unfortantly, due to the old clutch being completely rooted and near destroyed.... ran into a few problems last night when fitting the new one, so a new cover thing needs to be replaced which can be brought today as everything was closed last night.
Had to again reschedule the tune and dyno run again for this morning and have delayed it till next week.
Was looking forward to this mornings dyno run!
Were you selling this car a while ago?
What made you change your mind?
Yeah, was selling it a few months back.
2 people were interested.
1st - applied for a loan but fell through/wasn't approved.
2nd - another person said he`ll find the dosh for it and never heard from him again.
Was going to go for a GTR. But thought I keep a interest in the GTST and see what I can really do with it!
Well.... clutch I will have to get use to, thats for sure.
It is a bit like a button clutch but, can still ride it a bit.
did NOT stall it once last night!
But all up, this car has some serious balls and is running way better then expected.
cant wait for the tune up on tuesday.
gawd that clutch looks like itl be a bitch to drive!! I recently had a brass butt exedy clutch 1050kg clamping force installed in mine and traffic is a killer, feels like theres about 1cm of play between it being full on or off, not to mention the new found muscles in my leg from the weight of the peddle. Not real friendly but lays the power down very nicely :down: and apparently will handle very good for drifting
So... what's the deal with the clutch? The pictures you posted... is that yours? Or is the link to exedy site the one you have got? Because they are totally different! Has it been modified that much that it is now unsprung? Also the friction plates are totally different... :)
I do have to say from Thursday night though, that it looks very nice. Dan has done a neat and tidy job :mad:
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
