  • Replies 95
Car comes back again tonight with mesh behind the holes in the front bar and the indicator lights put in.
I'll take pics tomorrow when it's still day light.
Goes in for the full tune up and dyno run in the morning!
I'll post the results up once I get in here to work tomorrow.
http://www.exedy.com.au/clutch/hyperMultiPlate.htm
Thats the clutch i'm getting except it's been slightly modified to handle things alot better.
Dan might come on sometime and explain the clutch.
But from what Dan just told me, the clutch in the skyline now is absolutely rooted and it wouldnt of even lasted another week.
  Revhead said:
Looks like a button?
looks pretty much like my single plate 5 puck unsprung organic button clutch but in a multiplate.
its on or its off, it shudders, its noisy, its an absolute bitch in traffic. its there to handle the torque my cars setup puts out you get used to it but why youd sign up for that unless you needed it is kinda beyond me.
otherwise my clutches end up like this
but seriously, it seems like overkill
  Bobjones said:
Belgarion I believe it is multiplate, twin I think from memory, exedy don't make a single plate clutch in a multi format.....
But good analysis of how it will be to use!!!
Unfortantly, due to the old clutch being completely rooted and near destroyed.... ran into a few problems last night when fitting the new one, so a new cover thing needs to be replaced which can be brought today as everything was closed last night.
Had to again reschedule the tune and dyno run again for this morning and have delayed it till next week.
Was looking forward to this mornings dyno run!
  JCMarshall_Law said:
Were you selling this car a while ago?
What made you change your mind?
Yeah, was selling it a few months back.
2 people were interested.
1st - applied for a loan but fell through/wasn't approved.
2nd - another person said he`ll find the dosh for it and never heard from him again.
Was going to go for a GTR. But thought I keep a interest in the GTST and see what I can really do with it!
Well.... clutch I will have to get use to, thats for sure.
It is a bit like a button clutch but, can still ride it a bit.
did NOT stall it once last night!
But all up, this car has some serious balls and is running way better then expected.
cant wait for the tune up on tuesday.
gawd that clutch looks like itl be a bitch to drive!! I recently had a brass butt exedy clutch 1050kg clamping force installed in mine and traffic is a killer, feels like theres about 1cm of play between it being full on or off, not to mention the new found muscles in my leg from the weight of the peddle. Not real friendly but lays the power down very nicely :down: and apparently will handle very good for drifting
So... what's the deal with the clutch? The pictures you posted... is that yours? Or is the link to exedy site the one you have got? Because they are totally different! Has it been modified that much that it is now unsprung? Also the friction plates are totally different... :)
I do have to say from Thursday night though, that it looks very nice. Dan has done a neat and tidy job :mad:
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
