Don't be f**king stupid mark, you know that 21/22psi is bullshit. Judging by the graph, it's obviously run out of puff, and bumping it up to 20psi is hardly going to 'improve' this.
its out of "puff" cause the injectors are maxed out. not to worry right now though cause it's been set to rev out to 6,500rpm which has made it safer.
obvisously once the new injectors are in, everything will go back to standard.
  • Replies 95
That i'm not to sure about. Nick just stated that I can get 20psi out of a standard high flow turbo without busting anything internally or breaking anything at all.
However, to get the 20psi, the injectors would need upgrading which they should be arriving tomorrow or friday.
There will be plans to upgrade the turbo sometime later on into the year towards the end. Just got to get use to the power I have now.
On a straight T3 highflow power will be on the way down after 19-20psi.
It is physically impossible to get more airflow out of them.
And 20psi without busting anything internally is laughable.
If it is an unopened engine,,,,,It will eventually die.
Intersting
usualy when a car starts to lean up like that it makes more power
and if you arnt winding the boost down as it gets leaner i would start to think it's reaching max flow and running outa puff.
unless your retarding the timeing as it gets aroudn 6-7. its a wierd graph for a rb25
also should never run your injectors all the way to 100% :)
`josh
Why wouldn't I be?
I ran my RB20 injectors at 110% for nearly 6 months before upgrading them
Ok, Duty Cycle is the % of time the injector stays open (or has power), not the amount of flow, so you're saying that it stays open longer than the amount of time actually available.
I am not even going to go into how stupid that statement is. You can not have more than 100% of time unless you have unravled the mysteries of the cosmos and have a fridge powered by cold fusion.
I'm closing this thread in the name of science and all those bored by your crap.
That goes double for you John for regurgitating it.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
