Personally i would check out the Jaycar range of amps. My bro has one running his 12 inch Kicker, and i think he bridged it to run 450 watts rms @ 4 ohms. Either way the amp he is using is the 2 x 150 watts RMS model. Sounds great.
I dont know specs of the sub you are talking about, but i am sure you could find an amp in their range to run it nicely.
My 2 cents!
Catcha
this what i currently have....
IX252.jpg - the amp that is very under powered
88sl.gif - my cheep ass sub that i wanna hook up
kdc-mp8017_g-mp3.jpg - my MP3 head unit which is madd !!! i luv this thing
pioneer bullet splits taking care of the front while in the back i got some carrozzeria(??) speakers i think there a Jap version of pioneer???
anyways these are the amps im looking at getting to powerup the alpine sub....
==========all the amps here are under AUD$300=========
specs:
500 Watt Mosfet Power Amplifier
2 channel Bridgeable
Total Harmonic Distortion >.05%
Bass Boost Gain + 12db at 50 Hz
Low level input / output
Mosfet regulated power supply
Anti pop circuit
Overload protection circuit
Active Variable High/Low pass filters
Dimensions (w x h x d) 307 x 55 x 220 mm
specs:
Full chrome chassis design
Bridgable power 2 Ohm stable
MOSFET DC-DC switching power supply
Low pass toroidal transformers
Variable Low Pass Filter (LPF: 40Hz ~ 250Hz at 12dB)
Variable High Pass Filter (HPF: 40Hz ~ 1kHz at 12dB)
Three step crossover switch
Super Bass Control (6dB, 12dB at 50Hz)
Auto fan cooling system
Adjustable gain control
Auto power on/off by remote
Frequency response at 10~40,000Hz
Protection circuit (overlock, thermal, short)
Line-out RCA jack
4 ohm max. output @0.03% THD: 4 x 200W
4 ohm bridged output @0.02% THD: 2 x 400W
2 ohm WRMS output @0.1% THD: 4 x 200W
SNR 100dB
Stereo seperation: >55dB
Input sensitivity: 145mV - 2.4V
Input impedence: 10kohms
Operating Voltage: DC 12V
Speaker impedence: 4 ohms
Fuse rating: 20A x 2
Dimensions (WxHxD) mm: 320x53x263
specs:
Maximum Output Power (14.4V 4 Ohms)
120W x 2 350W x 1 Bridged Rated
60W x 2 at 20-20 kHz 0.08% THD
150W x 1 at Bridged 1 kHz 0.8% THD
Built in Low-pass filter 80Hz (12dB/oct)
Built in High pass filter 150Hz (12dB/oct)
2-Ohm Load Capability with rated Output Power 75W x 2 (at 1 kHz 0.8% THD)
Variable Input Sensitivity (0.2-5V)
Tri mode Operation with Optional Filter (KPX-T120)
Gold Plated Input/Output Terminals
Speaker Level Input from OEM Car Radio for Easy Up grade
Size (mm): 221 (W) x 57 (H) x 228 (D)
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
