Personally i would check out the Jaycar range of amps. My bro has one running his 12 inch Kicker, and i think he bridged it to run 450 watts rms @ 4 ohms. Either way the amp he is using is the 2 x 150 watts RMS model. Sounds great.
I dont know specs of the sub you are talking about, but i am sure you could find an amp in their range to run it nicely.
My 2 cents!
Catcha
this what i currently have....
IX252.jpg - the amp that is very under powered
88sl.gif - my cheep ass sub that i wanna hook up
kdc-mp8017_g-mp3.jpg - my MP3 head unit which is madd !!! i luv this thing
pioneer bullet splits taking care of the front while in the back i got some carrozzeria(??) speakers i think there a Jap version of pioneer???
anyways these are the amps im looking at getting to powerup the alpine sub....
==========all the amps here are under AUD$300=========
specs:
500 Watt Mosfet Power Amplifier
2 channel Bridgeable
Total Harmonic Distortion >.05%
Bass Boost Gain + 12db at 50 Hz
Low level input / output
Mosfet regulated power supply
Anti pop circuit
Overload protection circuit
Active Variable High/Low pass filters
Dimensions (w x h x d) 307 x 55 x 220 mm
specs:
Full chrome chassis design
Bridgable power 2 Ohm stable
MOSFET DC-DC switching power supply
Low pass toroidal transformers
Variable Low Pass Filter (LPF: 40Hz ~ 250Hz at 12dB)
Variable High Pass Filter (HPF: 40Hz ~ 1kHz at 12dB)
Three step crossover switch
Super Bass Control (6dB, 12dB at 50Hz)
Auto fan cooling system
Adjustable gain control
Auto power on/off by remote
Frequency response at 10~40,000Hz
Protection circuit (overlock, thermal, short)
Line-out RCA jack
4 ohm max. output @0.03% THD: 4 x 200W
4 ohm bridged output @0.02% THD: 2 x 400W
2 ohm WRMS output @0.1% THD: 4 x 200W
SNR 100dB
Stereo seperation: >55dB
Input sensitivity: 145mV - 2.4V
Input impedence: 10kohms
Operating Voltage: DC 12V
Speaker impedence: 4 ohms
Fuse rating: 20A x 2
Dimensions (WxHxD) mm: 320x53x263
specs:
Maximum Output Power (14.4V 4 Ohms)
120W x 2 350W x 1 Bridged Rated
60W x 2 at 20-20 kHz 0.08% THD
150W x 1 at Bridged 1 kHz 0.8% THD
Built in Low-pass filter 80Hz (12dB/oct)
Built in High pass filter 150Hz (12dB/oct)
2-Ohm Load Capability with rated Output Power 75W x 2 (at 1 kHz 0.8% THD)
Variable Input Sensitivity (0.2-5V)
Tri mode Operation with Optional Filter (KPX-T120)
Gold Plated Input/Output Terminals
Speaker Level Input from OEM Car Radio for Easy Up grade
Size (mm): 221 (W) x 57 (H) x 228 (D)
