SOLD !!!!!! SOLD!!!!!! SOLD!!!!!!
For sale 1993 R33 skyline in very good condition, Manual, 115,000 km's, *** 12 months rego***, has a few mods:
Exedy Heavy Duty clutch
Full 3inch turbo back exhaust system with high flow cat and dump pipe 4.5inch Invidia muffler
Full Tanabe suspension setup (non adjustable) Retail over $2,500
K&N pod filter
Custom cold air induction setup
Boost gauge
HKS turbo timer
Full stereo system (pioneer head unit with 6 cd stacker, kicker 6.5 inch splits front & rear with 4 channel amp running speakers)
Momo gear knob
GTR centre gauge cluster (just needs wiring up)
Side skirts & rear pods, series 2 rear spoiler
17 by 8.5 inch Zetti rims, with 245's on the rear and 225's michelin pilot sport tyres on the front
just had major service
Dynoed at a healthy 180 rwkw (dyno sheets to prove)
All work and servicing carryed out by Amberly Auto's AKA Horse Power Factory
Overall great car thats never given me any problems, hardly driven as I drive a truck for work. Reason for selling it, I am buying a house so need to sell it for a deposit.
Price: $13,400 ono no RWC
More photo's and details at carpoint.com and carsales.com
Contact me on 0407910304 or email me at [email protected]
Cheers Ryan
Edited by jetskyliner33
https://www.sau.com.au/forums/topic/109406-13400-r33-skyline-sold-sold/
  • Replies 85
Hey Ryan nice car, being someone who just sold a R33 s2 I can tell you guys want skylines for nothin' the problem is that the ppl who normaly want one cant afford it or cant even finace it!! and 1's wit money shy away cause of the "grey" factor, however nice car wish you the best danny!!!
Thanks danny your spot on about some of the people that have rang up or inquired TIME WASTERS!!!!!!!!!!!!! guess i just have to be patient
Leo2nv thanks for the reply, no there series 1, but ive put the series 2 boot spoiler on the back
can I ask peoples opinions on the price, do U think it is in the ball park figure for a 1993 model?????
cheers Ryan
hay mate i'm still searching, but honestly i don't have a cent over 15k so that's all i got, and seing as i am now goingto europe till July, i don't think i will buy anything till i get back.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
