hr31gtsx strikes back
fatz
 Share
  • Replies 44
i think it does a 17 second 1/4 mile.... dont know but *** its slow
give or take 10 seconds
duncan you know you want a side pipe bitch as ****!
and no it doesnt have a bent steering arm after the day
becasue i will fix it tommorow
then it will be as good as new
pete
yup car is 100% stock except the side pipes
it even funs 7 psi cause if i turn it up the turbo blows a bit of oil
such a fun car to punt around the track
car was sqatting so much it actually bent the passengers steering arm mid corner... and warped the front brake rotors.. and i need a new set of tyres
good excuse fr a 4 spot upgrade me thinks
pete
  • 3 weeks later...
 Share
    • Indeed. Mitsuoka always did their magic on various Nissan models, but because the Nouera was going to be in the medium sized sedan class, they decided not to try and modify the 2004 P12 Nissan Primera because it looked too modern combined with the 1940's styling. It would contrast way too much so they went with the more suitable CL7 Accord... 😆
    • It's also funny when an Australian company is boasting how their warehousing is USA/Europe...
    • Hi People, has anyone come up with a way of getting non-driven wheel speed on a R32 Gts/gtst? from what i've seen the RWD R32 didn't look to come with ABS, if they did i can't find a rwd ABS front knuckle anywhere. is it a case of putting a S14/R33 front knuckle on and then modifying the ASB ring to suit a ECU input frequency limit? or have people managed to get a hall sensor onto the back of the hub and pick up the wheel studs?   i've searched but there isn't anything that I could find.
    • I was thinking about a hoist, the ceiling is very high, but half the garage has a half-height loft for storage and I dont think I'll even be able to jack the X5 up under it as it almost hits me in my 6'5" elevated head when i walk in there. And, yeah nah, maybe if I can convince Bec to let me get another car she'd be open to having as many as we can fit (cough @Duncan) but until that time you better steer clear! 🤣
    • For the sake of cost comparison, I’m currently embarking on putting a new 5 speed into my R33. I imported a new RB25DET gearbox from Japan, which was about AU$3.3k delivered to my door. It was a very slow process (~2 months) and I got extremely lucky with the exchange rate. The twin plate clutch I bought was about AU$1.8k. I've also had to buy all the additional parts required to convert the gearbox from a pull type clutch to a push type clutch. Total cost is about AU$5.5k, so GTSBoy is pretty close to the money.
