Hi all,
Just hoping someone out there can help me with a problem my old man is having with his ST185.
He's getting white smoke coming from the exhaust & we're not sure where it's coming from. His mechanic told him it was the turbo, but upon removal, we found oil between the AFM & the compressor inlet.
A little background.......
Dad bought his GT4 a year ago. Blew a little smoke, but not too bad, mainly on start-up. Turbo started leaking water behind exhaust manifold (in the end it was the water feed gasket). I suggested changing the turbo for a high flow one (corruption!) which he did, along with a s/s dump & exhaust manifold (the type you see on e-bay).
Engine started detonating, which was tracked down to a cracked rubber hose between the compressor outlet & i/c inlet. Changed that & detonation still happens a little, but not as bad & above 4500rpm, but still not good.
Ok, now for the questions:
1. Is the detonation because of the high flow? How do we fix it - programmable ECU, bigger injectors, etc....
2. Where the hell is the oil coming from? I own a skyline GTR & I realise that with high revs some oil can make it's way from the rocker cover to the linlet duct, but the old man drives his GT4 like a volvo (ha ha ha) & this pretty much eliminates the possiblity of oil getting there under high revs.
Like I said there is oil before & after the compressor & in the intercooler, but not at the throttle body.
I'll post pics tommorrow to give you all a better idea of what I'm talking about.
Help please.........
Here's the AFM, the breather is between the AFM & the compressor inlet, so the AFM is getting pretty dirty.
Edited by yug_r34
Ok, I know that the e-bay gear leaves a bit to be desired, but changing dump & manifold shouldn't cause all these hassles.....
Can someone suggest where this oil is coming from, I think it's from the rocker cover as the hoses connecting the rocker cover & the turbo inlet pipe have oil in them. But what would cause oil to reach that far? Maybe blow-by & worn valve stem seals?
Cubes: White smoke happens when on boost, hard accelleration, maybe oil seal on turbine?
Edited by yug_r34
Oil in the combustion process causes detonation. It also coats the inside of the intercooler and oil is a great insulator, so you lose intercooler efficiency. Higher inlet temps cause detonation. Maybe the oil is the root of all of the problems. Try a temporary catch can (eg; Coke bottle) to make sure all of the oil stays out of the inlet. You can then measure exactly how much oil it is. Flush out the inside of the intercooler with 50/50 metho and kero, keeps flushing until it comes out clean. Wash with water and let dry in the sun.
Hope that helps
:P Cheers: D
Thanks Sydneykid, I didn't think that the oil could cause so many problems, but what you say does make sense. I'll do what you've recomended.
Originally we thought it was the turbo oil seal so we've pulled the turbo off for reco. Do you think we refit the turbo & try the catch can, suppose gaskets & a can are cheaper than a turbo rebuild.
Don't bother with a can to start with. Just use an old coke bottle and a piece of suitale size hose for testing. Cost = zero. If it makes a difference, then go out and buy a nice shiny one.
:) Cheers ;)
I would be checking that you PCV vavle is working as if it is blocked it will pressurise your entire crankcase including rocker covers which may be causing excessive blowby. You'll be able to blow thru it only one way thou; towards the intake pipe.
Edited by rob82
I'd be looking at the turbo
Oil is getting into your engine- I recon from the turbo get it checked
Maybe get the various gaskets checked as well [head, exaust, various turbo gaskets]
But a good clean of the pipes maybe all that is needed
I'm no mechanic but this is my two cents!
Edited by NAman
I would be checking that you PVC vavle is working as if it is blocked it will pressurise your entire crankcase including rocker covers which may be causing excessive blowby. You'll be able to blow thru it only one way thou; towards the intake pipe.
A busted pcv valve wont pressurise anything as there is a straight vent on the rocker cover running to the inlet pipe.
The pcv valve is an emmisions device that it sucked open by vacuum in the plenum and it is blown closed under boost so under boost any blow by will go out the breathers anyway.
BHDave, does this mean the boost will blow by & out the breather, into the turbo inlet pipe? Along with some oil?
What I meant to say is that if it was stuck open manifold pressure would then pressurise your crankcase system causing excess oil to vent into the intake pipe. Its a common problem on VL's. And does cause lots of oil smoke when the car is on boost.
    • Really, anyone modifying a car isn't being financially smart. We're doing it for the things we love. And honestly, a high revving, light, NA car is actually pretty darn fun. I used to have a Swift Sport, and I miss that thing as a daily, and yes, doing something like some intake and exhaust stuff would have made minimal gains, but would have bought an even bigger smile
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to motorsport@sauvic.com.au or print and hand in and Driver Sign In. email motorsport@sauvic.com.au To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email motorsport@sauvic.com.au Entry List: 1. Josh M 2. Anna 3. Luke  4. Katie 5. Martin 6. Tony 7. Alix 8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
    • Yeah, playing with naturally aspirated is not smart bang for your buck power wise, but then I've never been known for being smart when it comes to cars and modifications
    • I mean from V8 world there are gains to be made in intakes and such over stock items, but definitely only if you tune them. We're talking about I dunno, 10kw here and there on a 300KW v8, gains made by tuning in the 0.2 AFR that it changes so YES but also no you won't notice it other than the sound. Duct the air as mentioned 750,000 times and you will notice happier IAT's which definitely make a difference N/A. I mean my unsubstantiated guess is you'd go from 140kw with everything stock (after cams) to 145kw with everything and a tune :p
    • I decided to "spend baby spend", and "risk it for the biscuit" 2 Orders were made buying parts that I "don't really need but really really want" totalling $2.5k AUD 1: In stock items (intake plenum and throttle body) 2: The airbox thingie, with no real ETA for them getting more stock, so patience will be required
