It's the cars way of saying "i hate myself and i want to die, how could you do this to me!"
It's probably trying to hit any solid object on the out side of the corners in a vain attempt at suicide.
Hahahaha rotflmfao :down:
Yes agree with those under under comments, commodore looked like it handled slightly better *don's flame suit*
https://www.sau.com.au/forums/topic/109460-cool-vid/page/2/#findComment-2028716
yep def the perth v8 gts-t
interesting comment actually about the steering
even though it weighs 60kg less the steering is a bitch most likely because of the diff centrifugal force and torque distrubution - ie more cylinders and at an angle
and prob cause the engine is mounted slightly further forward to accomodate the extra 2 cylinders plus gearbox adaptaptions etc
so the weight is further forward = bitch steering
my opinion - based on physics :down::(
https://www.sau.com.au/forums/topic/109460-cool-vid/page/2/#findComment-2028857
"mounted slighty forward to accomodate the etra two cylidners"?
i dont know the actual dimensions for the gen3 or rb25, but im quite certain the v8 (having two banks for four cylinders) would be slightly *shorter* then an rb25, having one long six cylinder bank. i would have thought they could sit it slightly *back* rather then forward.
https://www.sau.com.au/forums/topic/109460-cool-vid/page/2/#findComment-2031309
    • bump. Anyone had this done? either 49 or 50mm? Been pondering what to do while mines in storage. Been thinking of DBW but if I do that, then might as well do this too. Want to retain 6 throttles. I have a fully build head(CNC, OS valves, 286/278 cams, etc etc still running squish), and a Greddy old school intake with port matching. Head bench flowed 300cfm. Wondering whether bigger throttles will give me any gains. Makes 563kw.
    • If anyone has any suggestions for a 300-350mm long (or thereabouts) muffler that is 3inch in and out I'm listening
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
