input bearing starting to make some noise so starting to save up for it but not sure who to go to.
Does anyone know what the cost's are? rest of box seems fine sycros, shifts etc.
If anyone has theirs done recently can they please recomend somewhere ? :cool:
https://www.sau.com.au/forums/topic/109497-gearbox-rebuild/
Dale @ K&A motorsports has done a few.
A few people go somewhere else, but i say go with who you are happy with. Just remember the service someone else got wont be the same you get.
To put a bearing set through the box costs around $450 in parts + labour ($200). This is with supplying the box out of the car.
i was quoted around $600 just to in / out the damn box (rb25det one)
https://www.sau.com.au/forums/topic/109497-gearbox-rebuild/#findComment-2016144
See Joe at JV Automotive (same place where Wheelworks is on South Rd, Joe owns both), they do good rates on labour to R&R the g'box, forgot who they sent my box to to have the 2nd gear synchro and snapped input shaft replaced replaced, but it was relatively cheap (also put in new clutch at the time)
https://www.sau.com.au/forums/topic/109497-gearbox-rebuild/#findComment-2028467
If anyone has theirs done recently can they please recomend somewhere ? :D
hey ive rcently done mine a full rebuild.
i pulled my box out and stripped it down and gave the gears still mounted to centre piece to a guy called Rick at Quinn Motors in Salisbury ph. 08 8258 8798 he was excellant and cheap i had new bearings done and he only charged $400.
i bought a second hand box so if ya need any parts give me a pm
also if ya have any Q's give me a pm
https://www.sau.com.au/forums/topic/109497-gearbox-rebuild/#findComment-2031772
is that $400 icluding parts and labour trick? (for an r33 box yer?)
Im gunna do the same as you to save some $$. I only need a bearing set put through. Did u have the syncro's done?
thanks :D
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/109497-gearbox-rebuild/#findComment-2031880
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
