With a range of free softwares now available these cables are a must have for anyone with a Nissan ECU and the grey 14 pin Consult Diagnostic port.
Serial Cable (RS232)
Direct USB Cable (comes with drivers)
This is the Nissan DDL or Consult port your car needs to have to work with these cables.
The serial ones are needed for NewKleers software for PDA's.
Payment is by direct deposit, acct details below
ANZ
Caroline Felgate
BSB: 012593
ACCT:565413726
Please ensure you put your forum nic on the deposit!!! and send me your address too please.
Cheers,
Caz.. :cool:
more info
Edited by caz
  • 1 month later...
stil selling these consult cables?! if u r i want 1 :) checked the pin on my R33, loks the same..and any ideas where to get this free software from? ;)
Hi,
Yes I still sell these cables, I am the Australian distributor.
I can give you links to some free downloads.
To purchase just drop me an email confirming deposit. Dont forget to put your nic on the deposit and send me your address!
Caz.. :D
stil selling these consult cables?! if u r i want 1 :D checked the pin on my R33, loks the same..and any ideas where to get this free software from? ;)
I've asked this before caz, so sorry for the same q.. How much for the USB cable + the Nis Scan or whatever the good sotware is?
Christian
Christian
Hi , i have a 1990 R32 GTST where is the OBDI port located and what features are supported via this ECU?
Thanks
  • 1 year later...
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
