Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Well Bel... Sounds all too familiar.
I had a ****ed up life at school. Especially year 12. My two best friends turned around and started calling me a fat whore.. and I never went anywhere anymore cause I was too fat.
That really ****ed me up. My confidence didn't exist.. I was soo down my immune system was none existant. I got sick at the drop of a hat. I put on 20 kilos in 5 months and never went to school.
My marks picked up cause my teachers helped me cause they knew what was going on. I didn't do well in high school and I now wish that i had just ignored them and got on with it.
But whats done is done.
I think most of my low self esteem stems from this. My two (what I thought) best friends ****ed me up.
Guest 87vlt
Originally posted by BelGarion
87vlt i went to a coed school, i came out pretty ****ed up, i got a shocking self esteem i hate myself, im terrified of girls after the ridicule i used to get at school.
dude just to let you know anyone who saw what I was like up until about 18 months ago would be able to tell you what kind of a mess I was in. If it wasn't for my mates, my mum, councilling and my Doctor I wouldn't be here today. I have been much further into depression than anyone of you can imagine. Boarding school wrecked my life. I hate gay people, lesbians included, I hate ****ly people, I have a problem with typical australias (ie eat steak, meat pies and drive v8s). I now have a very short temper and will go off my nut over the smallest things. and yet wehn I was at school I just stood back and took all the crap from the **** wits at school and kept quiet. Now i'm out of school If I see people I went to school with that pissed me off I go out of my way to make their life hard. It also now helps that I've grown 2 inches and put on about 30 kg :)
I don't think i talk to anyone from school anymore.
I was always taht little bit more mature than all of them and I didn't like anything they wanted to do. Like go to the movies and perv on the guys...
I'd rather go out all night cruising down the coast or go to willowbank with my dad than go out with them.
I've found a hell of a lot nicer friends now... They appreciate you for who you are... Not stereotype you against people at school
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
