Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Originally posted by GTS-t VSPEC
Dave,
Post the pic again.
I work at Murdoch Uni, where your friend will be doing Vet.
See'ya:burnout:
its on page 170-173 i think... but dont forget i have max posts per page... so all these gay "page to me" things dont even come up at the end/start of a page anyway.
yeh twin turbo.. i love it... breaks traction so easily... ask michael about it... all u do is put foot down , sit and wait 30secs while car burnouts then finally gets moving,, 30 metres down the road u re gain traction and your off... thats when its dry too..
with the skyline, i have to change gears to get smoke :D
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I donโ€™t really have any ideas how to set the timing on the CAS ๐Ÿ˜‚, sounds like the top, sounds like it maybe misfiring as well as ticking,ย  got the box sorted ๐Ÿ˜Œ, must of been a air bubble on the clutch side
ร—
ร—
