Queensland Wasteland
purely cos i can and its been recommended by a number of people i know with R33's :)
Anyway going to pick up my baby n give her a thrashing
nice chatting with u Erin. Paul dont spank off to buffy too much tonight. :)
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
I always behave :)
I've even finished doing my nails.
My cat's annoying me for food. She keeps running in. Meowing at me, smooching then running back to her bowl. It's very cute.
Each time she does i tell her I'll feed her soon. And I'm still sitting here!!
I just got my diff repaired.
It was basically reconditioned. The bearing had ****ed itself. I got a new bearing and relapped the crown and pinion. SO yeah..
Gavin (my mechanic) couldn't find a diff anywhere.
Heaps of people were just saying "go to a wreckers and buy a skyline diff". I kept saying "It's not that simple. I dont know what electrics would stuff up if I just put a normal diff in"
Ended up costing $1097. That was my intercooler money. But I decided that safety was more important than going faster.
With your diff.. If you start hearing a clicking/tapping noise coming from the back, then that noise goes away, then it turns into a wurring noise that starts at a certain speed (mine started at 110km and got worse) .....(cat's back again)
Anyway, yeah, that's when its bad. It was starting to make the noise at around 40kmp/h when I finally took it to the mechanic. It had also blown a seal before this and was leaking.
Admitadly it does sound like road noise and I thought this was the case cause I've got 255/40/17 profile tyres (there huge!) and so did my mechanic. But yeah, it wasn't.
And no, I don't have a FMIC.. I can't afford it atm. And my insurance doesn't allow it right now :)
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
