Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Thanks for the birthday wishes Erin :D had a great night.
its only now - 24hrs later - that the seediness is starting to kick in haha i actually bounded outta bed this morning - its a wonder how that happened considering the ammount i had to drink.
Everyone seemed to have a good time tho - huge mess to clean up this morning!
Originally posted by NismoGirl
I think it may be lieing...
I only get like 400 at the most out of my tank. That's freeway driving.
I'd be careful. Does your gauge work?
haha, thats even worse than mine!!! i get 420km out of a tank after cleaning my fuel filter... but mine is also a bit worse cos I have a higher diff ratio.. (pulls like 3150rpm @100km/h in 5th... std is 2700rpm.
well she's a stupid bitch then! Least u found out - u can go get yourself someone better now. Just dont start thinking thats what all us girls are like because we're not. Mustve hit like a tonne of bricks tho *hugs*
So u really liked/loved her then? Once you've destroyed trust thats it :D just do whatever u have to to get her outta ya system wont happen overnight but it will happen :D Just gotta surround yaself with your good friends.
yeah it was my birthday party last night - so the place is a mess - ive cleaned it up pretty much just gotta mop the floor and wipe down kitchen. just soooo much easier to sit here tho.
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
