Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
I got my car serviced on Friday. It's not running very well. I dont know whats happened. It's cutting out at idle and the revs aren't picking up by themselves when I first start the car. I've got to stab the accelorator to start it.
ANd I need to get my timing belt changed :) Doh!
Guest Boxhead
yeh thats basicaly whats happening to myn, but its got new spark plugs.. well newish, and it started great with the battery was new, but the new one is dying coz its not charging back up when i drive( which is alternators fault again!!! grrr...
ohwell.. erin - seriously check your battery indicator thing to tell you how charged it is.
Well mine only has the problem that you have to give it a bit of gas to start when cold...then the revs pick right up. Other than that all is sweet.
I've seen quite a few photos now that Justdave has taken of your car....i just assumed that he liked it. :D
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
