Can a jammed actuator cause black smoke on boost somehow?
Yeah, whenever I say "HP", I mean HP. As in, at the engine. Allowing for a 25% discount from engine to typical Ozzie braked roller dyno figures, then subtracting the usual (more optimistic) US inertia dyno offset..... you get into the 600 actual engine HP territory from your 484 wheel number. 484 / 0.75 = 645 (that's Aussie rw intertia HP, converting to approximate engine HP. 645 --> 600 is discount for inertia dyno. Could actually be worse than that. But that would still be up around 600. So near enough for purposes.
Still fast enough to have fun (kinda). Time for a modern turbo with a divided turbine housing and a proper twin scroll manifold. I think 400-450kW is a great place to be, provided it's all in before 4500 rpm. -
i'm not at 600 though 😢 its 484hp (356kw) at the wheels..
Nice. 600ish HP is probably a nice place to be.
