Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest neoGT-25
yeh i mean a bolt on kit... i dont know much about them tho :(
anyone got any information on what sort of kits there are?
also what other things would i need to do to my car for turbo (apart from fmic and stuff) internal parts would need changing wouldent they?
im not ready yet but id love to learn this stuff... cant hurt ;)
PS: BelGarion, i love you new exhaust :( its L337 but sorry about your girl :D
PPS: I want a turbo but i dont want to change my engine cos i love the neo... it looks sexy and has less K's on the clock...
thanks for any help you can give, bye all :burnout:
Guest neoGT-25
Oh and also... has every one seen Getaway In Stockholm?
i downloaded one with a black Porche 911 with mods :( damn it was the best movie i d/led off KaZaA ever! (yes better than pron :() not that i ever look at that stuff :):innocent:;)
meh... everyone should d/l it... the file is called "F*ck the police" (rude name but the video rocks :D
enjoy :uh-huh: :burnout:
byes.
mmmm just looked at the last 3 topics and i was the last to post in em, could it be that i am becoming a post whore? think i might need to reduce my time spent on the internet.
tho with fuel prices the way they are, its almost cheaper to stay at home, but then wheres the fun in that ey :D
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
