Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest 87vlt
Originally posted by BelGarion
yer good, yer another ****ing dickhead attacking me again
your right man, i wouldnt have a clue cause my boost guage says 7psi and it doesnt waver till later in the rev range for 9psi, once it hits these marks it doesnt move, mabey i should throw it out
its a ****ing catback u tool, thats it, the boost does not spike, jump or whatever, but then again what the **** would i know, its not like i have a clue what the **** im on about,  there is no ****ing bleed valve, there is no punched out cat or dump pipe or anything, yet im running 14.1, so mabey willowbanks timing gear is ****ed too, got anything else to blame it on?
you ****ing got up people for raggin on your car, your no bloody better yourself you jerk
9 psi is a bit higher than the stock 7 psi ...... I think it has made a difference by putting on a cat back exhaust ..... god damn you take shit to seriously, my point was that was quicker than the supposed 14.5 times nissan quotes. Which I'm happy for you.
Guest Boxhead
i like that last post :)
thats the way we all should care about it..
hahaha, well atleast i do..
umm but seriously guys, even iff for eg, i was to run my car on the 1/4 and i was getting shitty times, then i for some reason started inscreasing without mods...
dont you think maybe ive fine tuned my dragging technique..
and 87vlt - dont whinge about that, coz you know you were annoyed when someone else did it to you
Guest 87vlt
im complaining bout bein single
oh and i ripped into 87vlt for accusing my car of running more boost than the boost guage says
Seriously man stop getting abusive otherwise you'll end up ban like I was. I want to discuss this in a mature manner. Where do I meantion a boost gauge? I said stock boost ..... not what your boost gauge said. You don't need a bleed valve to increase boost by small amounts. Small changes like the strength of the actuator pull, more free flowing exhausts, etc increase the boost, only slight but its still there. This is what I believe has contributed to you getting such a good time with a car thats almost stock car and dude you should care cause its not just a car that gets it to those times.
ill take the catback off, it will still have 7psi below 5000rpm and 9psi above 5000rpm
thats the way r33s are from factory.....
hell if ur that desperate to prove it wrong, ill take my exhaust off and drive it round the block
1. ull see no change in the boost
2. ull pass out from the gasses
3. cops will be called cause of noise
but it will still be 7psi below 5krpm and 9 above it
or you could make up an exhaust that goes from the turbo down to just under the firewall, and drive around on the road like someone i know, who was subsequently caught and fined.
Sounds wicked, turbo spools so loudly, neighbours dont like it so much.
Guest
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
