Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
I'm not sure Scott..
I'll ask if I can give you his number. The coolers are 600x300x70 (i think) so they are a fair size.
When i rang and asked I said "I want that whole in my front bar taken up with a whole intercooler" he goes "that's what everyone wants so that's what I do"
:D
i did some recent cooler shopping, heres what i found:
600x300x75 "Universal" intercooler
$770 @ rolin auto imports
$660 @ STZ Automotive
exact same cooler
tho the coolers dont look to flash and the way they were treated at one of the mentioned workshops was pretty poorly... bent fins everywhere... scratches and all that.
i bought a 600x275x55 from a guy on performance forums.
Aftermarket cooler inlet: 25deg cruise 39deg on full boost
stocko cooler inlet: 41deg cruise 70+deg on fullboost
my car still feels slow as poo tho.. and its been tuned
201hp@wheels... about 150rwkw
605ft.lb of torque = 820Nm of torque... i think thats half decent
mods:
r32 silver top rb20det 5spd
EMS dual sport
K'n'N pod
CAI
r32 highflowed turbo (steel wheels)
600x275x55 cooler
3" turbo back exhaust
10psi boost
550hp fuel pump
i have worked out what i need to do to boost control (instruction manuals ARE useful) but i have to adjust a number.. that is a Pulse Width Modulator frequency.. that in turn some how controls the EMS boost solenoid
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
