Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
i didnt run last night because im selling my car... its killing me!!! if i come back from overseas and i havent sold the car... i will be boosting so it makes 450rwhp, buy some slicks then take it down the 1/4.... otherwise i wont be seeing the 1/4 for a long time... i just had to come out and watch... cant stay at home when u know the runs are on!!
Guest 87vlt
Originally posted by Skyrine-Dave
should i build an RB25/30 combo, find a cheap RB25det, or bolt a HKS2530 to my current RB20det?
rb25 ... too much custom stuff in a rb25rb30 engine. the rb20 .... meh ... they may be faster than me but don't really impress me by any means.
Guest 87vlt
boxhead .... did you break out into insane amounts of wheelspin to get that time? if you did you da man ...... looks damn kewl from a spectators point of view. Seeing one car in one lane getting a nice smooth launch and another sitting on the spot spinning its arse off .... :P
Guest
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
