Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Lucky there was dew all over the car and it didn't set. Lucky the spastics had no aim. One egg hit my mag, the other hit the drivers side mirror and the front quarter panel. The only reason I noticed it was the car looked extra shiney to be just dew and there were streak marks in the dew. Lucky I care for my car enough to look at things like that.
THEN I went to start the car and the battery was flat. It was soo flat it wouldn't clutch down our hill. Ended up having to jump start it, drive it to a carwash place, high pressure hose the egg off and then come home. By that time it was 2am and I was ****ed.
Last week I had someone put stickers on it.
Pretty damn sick of it. Time to invest in a shed I think
Guest Boxhead
erin - im sorry to hear that, if you ever happen to find the little shits, instead of pouring eggs on there car, put some battery acid.. and then invest in a nice hand held weapon, maybe a colt .45 and just sit and wait... next time they come back, aim for the spine, dont try and kill, just paralise...
Guest Boxhead
kryz - there is this bloody huge pot hoel out teh front of my house.. just out from my driveway, every time we come in and out of it in my car we gotta look out for it...
im tempted to fix it myself coz i know council are assholes...
its like say 50cm round and same down
Guest
