Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Originally posted by rb25
eF5ive
All I can say is you guys have gota lot to learn about whoring.
Even Bel has migrated to WA cos the refresh crap is so ghey.
If your trying to get your postcount up , be a bit more creative about it and post something worth looking at.
Hopefully the mods will put a stop to this sort of crap ( yes even in wasteland this is rubbish ) in an attempt to stop wasted server space.:)
Cheers
Ken
Originally posted by Boxhead
ken whoring is whoring... even with crap or not its still whoring, if they delete our posts coz there whoring, they should delete all whoring posts.
No it's not.
Whoring is talking about non essential stuff or non technical.
Even gday or night is fine as it is a proper post.
What good does pressing F5 , refresh or just counting do except increase your post count.
And I still can't see why you guys get so excited about top of page.
We stopped worrying about that around 600 pages ago.
The only credit we gave is if you can bookend ( top AND bottom of std page )
Cheers
Ken
Guest
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
