Just changing my front shocks - dropped down the new and old to be swapped at the local mechanic. I.e I took the shock dpring assemblies out of car so car sitting here shockless..
I've been waiting for a day or 2 now and was wondering whether I should invest in a spring compressor??
Always been scared of horror stories with these. Are there any that are around $50 that are safe?
Edited by benl1981
https://www.sau.com.au/forums/topic/109585-what-spring-compressors-do-you-use/
I just went to my local Autobarn and bought whatever they had. Seem to work OK.
Only problem I've ever had is that they tend to twist along the coil - just keep an eye on them and keep them parallel as best you can.
The horror stories would come from not using them - simply undoing the top nut while the spring is under compression, parts shoot off everywhere.
i'm not a fan of the the autobarn etc ones as they twist and somtimes don't grab 100% due to the angle of the taper on some springs. and they're just awkward and take forever. for $175 most industrial tool places will sell you a big ass thing on a stand that locks the whole assembly in clamps and has a hydraulic ram that compresses the spring using a foot pump. very weapons grade and not expensive compared to what a lot of places charge for r and r of springs etc. huge convenience factor if you change springs a bit and if you share the cost with 3 mates it's peanuts.
We have a spring compressor like Scooby described in the workshop, it's a great thing when you need to swap springs many time a day. Or if you are doing Mercedes springs with tonnes of pre-load. It's an overkill for a home garage where you might do one set of springs a year. Particulary on a Skyline that has very little pre-load in comparison.
I have a pair of $25 spring compressors that I bought from SupaCheap a couple of years ago. Carefully used, they have done over 10 sets of Skyline springs without a problem. I just make sure I keep myself out of the firing line.
;) cheers :)
Edited by Sydneykid
Hey guys - thanks.
I just borrowed some from my local mechanic - so heopefully won't injure myself!!
A mate of mine had a set of super cheap spring compressors braeak on him...not a pretty sight. As a general rule, I avoid placing my life in the hands of anything Chinese.
The bottom is free now - I can twist it, however the top seems to still be under a bit of tension. I guess cause I didn't grasp it close enough to the top.
Will this give a bit of impact as I loosen off the remainder of the top bolt..or make it harder to put the compressed spring on the new shock??
http://img93.imageshack.us/my.php?image=img00334iy.jpg
Edited by benl1981
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
