$60 dollars for a new set mate, if they are fouled dont be a cheap skate or you might pay for it in the long run. {new motor} etc. what you should be asking is a mechanic to look into why they fouled up .
good luck anyway :D
Consensus tends to be that you don't clean Iridiums. I've just put mine in and won't be touching them for a while. If they're fouled you'd be best replacing them and working out why they fouled so easily and fixing that problem. Otherwise, you'll just keep going through plugs. You should replace them either way, the choice is really do you fix the problem then get some fresh Iridium's or disregard the fouling issue and just swap coppers omre regularly.
Good luck
I dont know why anyone bothers with iridiums or platinums.
Ive had them and yeah they last longer but dont perform any better. I mean its a pretty substantial dent in a budget for plugs.
Copper ones you can pay for fuel, grab a set and throw them in every few months and it costs f**k all! No need to cleen something that costs $4! Who gives a f**k, throw it out and but a new one.
Plugs shouldn't need cleaning if they are fouled your mixture is rich. A correct mixture will keep the plugs clean. Plugs arent finished when they are fouled! They are finished when they are domed. As i said if its fouled fix the mixture not the plug. This will in turn clean up the plugs by itself after driving...
Deren
I agree with Godzilla32,Thirty years of motor sport tells me that fouled plugs are mearly unburnt crap on your otherwise perfect plugs.A spark plug is a mechanical device,fouling it will not change it`s basic structure.Clean it, that will work fine unless it has over heated at some stage.
If the plug is fouled enough not to fire it will never clean up even if you fix the original problem....and the iridium and platinum plugs are almost impossible to clean without damaging the electrodes.
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
