tem: 1995 Nissan Skyline R33 GTS-t
Website: http://www.skylinesaustralia.com/forums/in...howtopic=109628
Item Condition: Great
Reason for Selling: Looking to downgrade, need cash
Price and Payment Conditions: ANY OFFER OVER $17,000 WILL NOT BE REFUSED!!!
Extra Info:
Engine:
-Highflowed standard r33 turbo
-3"dump pipe into high flow cat, 3 1/2" cat back HKS exhaust into X-Force Cannon w/ 5" tip
-Apexi electronic boost controller
-Hybrid front mount intercooler kit w/ 600mm/300mm/76mm intercooler core
-Wolf 3d fully tuneable aftermarket ECU with hand controller
-Simota airpod filter
-Iridium Spark Plugs
-GTR fuel pump
Driveline:
-Standard 5 sp box with heavy duty clutch
Body:
-Modified front bar with centre section cut out to fit intercooler, and repainted
-Series 2 rear wing
-nismo decals under side repeaters
-HKS decal on boot
Brakes/Suspension/wheels:
-Standard r33 calipers and rotors
-Bendix ultimate pads
-HSD fully adjustable coilovers with height/dampner/camber control
-19" 5 spoke shadow chrome wheels, with polished dish
-235/35/19 nankang front tyres, 235/35/19 marshall rear tyres
Interior:
-Apexi AVC-r controller dash mounted, can give guage readouts for speed, boost, revs, duty cycle etc
-Wolf 3d hand controller
-Dash repainted in white same colour as the car
-all seats and trim standard r33 gear
-genuine momo alloy gear knob
Stereo:
-Sony CD headunit
-Kenwood KFC-M7145IE 500W 7x10's Front Speakers custom mounted in the doors
-Kenwood KFC-M7145IE 500W 7x10's Rear Speakers fitted in custom parcell shelf
Has all the standard features of the gtst including power windows/mirrors, climate controlled air conditioning (18-30 degree range) drivers airbag, leather wrapped steering wheel and gear boot
- Made 300hp/230kW atw on 1.1bar boost (16psi)
- Serviced every 5000km/s with synthetic oil etc
- Mainly ran on standard boost (7-8psi)
-Had approx $20,000+ spent on it, and most mods done within the last 18 months
Any q's give us a txt or call on 0407217325
Pictures: Clicky
Contact Details: 0407217325 or 0265834374
Edited by Satanic_R33
  • Replies 62
i got a candy red honda integra 95 model vtir selling at 16500 ONO... i havent got cash to give u as ur cars for sale at $20500... if u want work out something with taking a few extras off ur car and get back to me if ur interested for a straight swap..... if i did have the cash i woulda considered something but as i am after something around my price range for a swap.. cant find no one.. :D Good luck with the sale neway if ur not interested
Firstly nice ride hey :D Mate I've got an R32 GTS-T was looking for around $15K. Pretty stock, cooler, 3inch turbo back exhaust, 18 inch tyres, Alpine stereo,painted interior, will have fresh respray soon. Goes really well, regular oil changes. Rego till September. Not sure about cash aswell but its on the table anyway.
Cheers
Guest
 Share
    • Standing around having photos taken on insta. (sad but true). Go to a track day, what is actually there nowadays could suprise you, you need to update your cool car in the hill radar to include VW, Hyundai, BMW etc
    • Hello again, I just want to tell you that i found the reason why my bnr32 is going out in right corners. I had my car tuned by a company and they fitted the Emu Classic and a new fuel pump in 2021. I checked the loom, changed the walbro fuel pump with a Deatschwerks fuel pump. None of this helped. Then I checked the fuel pressure and thought I was crazy. It was tuned with over 7 bar ( over 100psi) !!! But why? So I checked the fuel return line and saw that it was closed. That was probably also the reason why the tuner replaced the fuel pump, but he tuned the Emu with the 7 bar 🫣 The map in the emu has now been changed and evertyhing is fine.
    • I'm going to vote for considering going to the effort to close the lash down to the minimum. My bro-in-law got around to checking the clearances on the 3SGE in his Caldina. Was a bit fat all over. New shims at lowest allowable lash, and the car is remarkably better to drive. It appears that the increase in both total lift and duration that you get from doing this is worth a lot more than you might expect. I have been having evil (and expensive and time consuming) thoughts about doing it to mine, and I don't even think I have a problem. Not that I'd know, though.
    • Thanks for that, it actually sounds fine to me. What oil weight are you running and what kind of oil pressure do you see around idle RPM and a bit over it?
    • https://youtu.be/CCHaKUhZi34?si=PNdluupk9TWFtvws
