Ok guys i dont no if your going to be able to help me but there is a funny squeeling noise coming from my rite left now it started the other week but when ever i wash the car it stops. im thinkin it is the brakes are stuffd but if any1 has had a similar thing hapen i would love tohere
https://www.sau.com.au/forums/topic/109632-funny-noise-coming-from-brakes/
I believe excessive dust can cause squeeling. Everytime you wash it out its ok. Maybe the pads your using have a high dust release content. Also check your rotors for grooves..maybe you got a small stone or chip stuck between the pad and rotor?
From wat i can see i have plenty left. R33 Racer i do live on 300metres of dirt road so im guessing that could be the case i have looked for a groove in the rotor an none there. But the thing that is puzzling me is i have had the car for over 12 months an this is the first time it has happened o well im changing the pads tomorrow so hopefully it will fix it. Cheers Jamie
might want to hit it with some brake cleaner, it's quite common for brakes to squeek (sit at a busy intersection for 10 minutes and every second car will have brake squeek), it's usually not a major problem, more of an annoyance. It's basically caused by the back of the brake pad vibrating/rubbing against where it touches the caliper, normally you put some anti-squeel grease on it when you put pads in.
You can get free brake safety checks at most brake places so might be an idea to go down and get their opinion on it.
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
