OK guys ive got around 2k to spend on my Skyline
Current engine mods that came with the car are:
3inch Stainless cat back
Pod filter (not heat shield)
BOV
Now this is what im looking at spending my money on. Please give other sugestions.
3'inch twin dump pipe from Bosimporting $450
3' catco cat (just the $280 one) from Bosimporting
Oil catch can $70
Just Jap intercooler and kit $550
Boost gauge $70
This totals around $1400 plus freight.
Other things i was thinking about getting are.
A box for my pod with CAI setup
New fuel pump Bosch 040
Please give ideas
https://www.sau.com.au/forums/topic/109648-spending-2k-on-basic-mods/
if you are purcashin from bos (spilt dump pipe)-make sure the sensors on the pipe have been relocated as his first batch had problems.. Not to sure if he has fixed it or not yet..
Or i would purchase CES spilt dump pipe.. Costs a lot more, but probably worth it..
Why do you need a catch can right now?? You arent gettin any detonations right??
So i would finish exhaust off from turbo back, with hiflow cat.. I would also get cam gears(exhaust)..
Front mount, heatsheild for your pod (i might be sellin mine in a months time or so as i wanna get a carbon fibre one lol), then boost controller.. Also a new fuel pump will help!!
get a power fc and tune it..
Then if you got money left over, i would then buy small things, like boost guage etc etc..
thats all you bascailly need to get 200rkw..
Edited by siddr20
I was going to get a catch can just because there cheap and i beleive it stopes all the crap going into your intake?? There is no detonations.
With the cam gear would i need a after market computer? if not would i need to get the car on the dyno to tune it with the cam gear?? where can i get a cam gear from?
My idea is to get all the mods done up towards getting a Power FC. As i cant afford a Power FC now and tune.
Cheers.
I would buy a stock airbox with a decent panel filter to replace the pod filter. Pod filter is going to cost you performance in terms of day to day driving.
A guy on this forum has made up some boxes that fully seal the pod up, and the air is fed through the stock snorcle. There around $120 each... This is what i was thinking of getting. i guess it would be similar to the stock box and panel filter?
^^ yup thats what i got, from mr_crust.. usin stock snorkle..
you can get cam gears anywhere.. www.nismo.com.au justjap.. any sponsers..
It will be tricky to put in yourself, so when you are ready for powerfc tune, get that mechanic to put it in for you..
However theres a few threads on here about it..
It does gain 10-15kw.. so huge power increase -- i have been told.
The above makes a lot of sense. The key is in fitting a Power FC, freeing up of exhaust and a suitable boost controller. I'm not sure what type of turbo impeller you have (ceramic or metal),metal is another key in this department as running over 1 bar with ceramic spells trouble. You will need metal impellers if running over 1 bar. Of course a larger intercooler would be nice. But as we know with Skylines they can suck up a lot of moola ($$$)
If you have stock turbo this is all you need!!
Intercooler $550 or go R34 SMIC for under $200 (if plan for bigger things later go the FMIC)
3" Dump/front $250 or pay extra to go split
high flow cat $180 (BATMBL Catco 3")
Boost controller $30 (from forums)
Stock BOV $30 (sell your aftermarket one for $)
Stock Airbox & Snorkel $50
High flow panel (pipercross) $60
Sell your POD
Raise boost to 10-11psi.
Buy PFC $1000
Tune $300-$400 (get the tuner to do one power run on base map to see that is running rich, or check fuel rail pressure to ascertain condition of stock pump, before he gets down the track of tuning) Stock fuel pump should be ok!
You will net about 180+rwkw of very nice responsive power without drawing attention to yourself.
All up about $2-2.5k
Edited by benl1981
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
