OK guys ive got around 2k to spend on my Skyline
Current engine mods that came with the car are:
3inch Stainless cat back
Pod filter (not heat shield)
BOV
Now this is what im looking at spending my money on. Please give other sugestions.
3'inch twin dump pipe from Bosimporting $450
3' catco cat (just the $280 one) from Bosimporting
Oil catch can $70
Just Jap intercooler and kit $550
Boost gauge $70
This totals around $1400 plus freight.
Other things i was thinking about getting are.
A box for my pod with CAI setup
New fuel pump Bosch 040
Please give ideas
https://www.sau.com.au/forums/topic/109648-spending-2k-on-basic-mods/
if you are purcashin from bos (spilt dump pipe)-make sure the sensors on the pipe have been relocated as his first batch had problems.. Not to sure if he has fixed it or not yet..
Or i would purchase CES spilt dump pipe.. Costs a lot more, but probably worth it..
Why do you need a catch can right now?? You arent gettin any detonations right??
So i would finish exhaust off from turbo back, with hiflow cat.. I would also get cam gears(exhaust)..
Front mount, heatsheild for your pod (i might be sellin mine in a months time or so as i wanna get a carbon fibre one lol), then boost controller.. Also a new fuel pump will help!!
get a power fc and tune it..
Then if you got money left over, i would then buy small things, like boost guage etc etc..
thats all you bascailly need to get 200rkw..
Edited by siddr20
I was going to get a catch can just because there cheap and i beleive it stopes all the crap going into your intake?? There is no detonations.
With the cam gear would i need a after market computer? if not would i need to get the car on the dyno to tune it with the cam gear?? where can i get a cam gear from?
My idea is to get all the mods done up towards getting a Power FC. As i cant afford a Power FC now and tune.
Cheers.
I would buy a stock airbox with a decent panel filter to replace the pod filter. Pod filter is going to cost you performance in terms of day to day driving.
A guy on this forum has made up some boxes that fully seal the pod up, and the air is fed through the stock snorcle. There around $120 each... This is what i was thinking of getting. i guess it would be similar to the stock box and panel filter?
^^ yup thats what i got, from mr_crust.. usin stock snorkle..
you can get cam gears anywhere.. www.nismo.com.au justjap.. any sponsers..
It will be tricky to put in yourself, so when you are ready for powerfc tune, get that mechanic to put it in for you..
However theres a few threads on here about it..
It does gain 10-15kw.. so huge power increase -- i have been told.
The above makes a lot of sense. The key is in fitting a Power FC, freeing up of exhaust and a suitable boost controller. I'm not sure what type of turbo impeller you have (ceramic or metal),metal is another key in this department as running over 1 bar with ceramic spells trouble. You will need metal impellers if running over 1 bar. Of course a larger intercooler would be nice. But as we know with Skylines they can suck up a lot of moola ($$$)
If you have stock turbo this is all you need!!
Intercooler $550 or go R34 SMIC for under $200 (if plan for bigger things later go the FMIC)
3" Dump/front $250 or pay extra to go split
high flow cat $180 (BATMBL Catco 3")
Boost controller $30 (from forums)
Stock BOV $30 (sell your aftermarket one for $)
Stock Airbox & Snorkel $50
High flow panel (pipercross) $60
Sell your POD
Raise boost to 10-11psi.
Buy PFC $1000
Tune $300-$400 (get the tuner to do one power run on base map to see that is running rich, or check fuel rail pressure to ascertain condition of stock pump, before he gets down the track of tuning) Stock fuel pump should be ok!
You will net about 180+rwkw of very nice responsive power without drawing attention to yourself.
All up about $2-2.5k
Edited by benl1981
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
