Hey all,
I'm looking for a new car, and I love skyline's.
I've been looking around, and I've found a 1994 R33 GTS4 5-speed-manual for sale for $12,990. As far as I can tell, the GTS4 is a non-turbo 2.5L (RB25DE) All Wheel Drive. This exact car is a 2door Coupe, with 130,000 on the clock, plus a few mods (exhaust, pod from a 300zx, gtr front grill, stereo etc...).
I just want to ask if this sounds like a good deal. It seems like it is to me, but it is a non-turbo with 130,000kms.
Thanks all,
RoD
https://www.sau.com.au/forums/topic/109658-r33-gts4/
Originally I was looking at an R33 GTS-t, but I'm 19 and only have a part-time job (I have uni 4 days a week). A non-turbo costs half as much to insure as a turbo, plus I figure it should be lower maintainence, since there'll be less strain on the car.
One thing I really want to know is if it will still be in decent condition after 130,000kms? I've read that unmodified skylines (R32/R33/R34) are pretty reliable, but I can't find much info about the GTS4. I plan to get a full inspection done by the RAC anyway, but I would like some of your opinions, especially if anyone here has had a GTS4.
Thanks again
RoD
https://www.sau.com.au/forums/topic/109658-r33-gts4/#findComment-2022345
Thanks for all the advice so far. I got a couple more questions here.
How fuel efficient would the RB25DE be? I figure that since it's not turbo, it shouldn't be a massive fuel hog (not as bad as the RB25DET anyway).
Also, am I right in thinking that it needs/prefers to be run on Premium petrol, or is that only for Turbo models?
RoD
https://www.sau.com.au/forums/topic/109658-r33-gts4/#findComment-2022875
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
