Hi All,
Just looking around at options as far as wheels go and R32 GT-R stockers are looking pretty appealing to me. I was interested to hear from those who have fitted R32 GT-R rims to their R32 GTS-t's, specifically those with lowered suspension. Did you find it scraped out much? I'm assuming guard rolling is advisable. With the guards rolled and the car lowered is the fit reasonable? I don't particularly want the hassle of scraping out and rubbing 24/7.
I've found a few answers but would like a few more opinions first.
Regards,
Ryan
https://www.sau.com.au/forums/topic/109678-r32-gt-r-wheels-on-r32-gts-t/
yeh ur right... whats the diff between gtr and gtst? offset or something
yes GTR wheels have a lower offset (ie more track) and are 1.5 inches wider and are lightweight forged aluminium wheels. GTST wheels are cast.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
