G'Day Guys,
I've just imported a R33 GTR, which has a sweet paint job btw, and I've been told one of the best alarms out there is the Viper 791XV. I had a look at it and others but really liked what the Viper offered, so I bought it.
Now the big question is who can install it in Tassie???
Any recommendations???
I'm after service, service, service, because I will be going BACK to them for other things down the road.
I'm not to fussy about cost IF I can get the service and the experience, to back me up.
Thx
Greebo
btw I'm flying over to Melb to pick her up on Friday!!! I am SO pumped/jazzed/exicited, whatever you want to call it ;)
https://www.sau.com.au/forums/topic/109708-alarm-installers-in-tassie/
G'Day Guys,
Thx
Greebo
btw I'm flying over to Melb to pick her up on Friday!!! I am SO pumped/jazzed/exicited, whatever you want to call it :no:
Greebo where about are you located, i know plenty of installers throughout Tassie.
Drop in to the Tassie section: http://www.skylinesaustralia.com/forums/in...hp?showforum=27
introduce yourself and get some pics up of that sweet sounding ride.
Depending on where you are located and what you are into i might be able to help out with other things with the car community for Tassie as well :mad:
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
