HOW MUCH STORAGE DO YOU HAVE?
61 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
this machine work has a 40g drive in it. Hard core, and onboard gfx and all :lol:
home media machine has a 300g and an 80g
home games machine has one 80g
hard drive is the thing on the back end of the computer with taht big fan in it Dasblitz
  • Replies 67
LoL..
I made this thread to get an idea of what the average Joe has for storage.
My range of PC's come out with 160 ~ 200GB hard drives at the moment and that seems the accepatble storage size for most new PC's.
However having said that 250GB drives are getting extreemly cheap now, probably due to the new wave of 600 + GB Hard drives hitting the market soon.
Sizes have been pushed higher and higher due to the Digital Video Storage requirments of HD TV and SD Digital TV recording.
For example My Media Center Records HD TV at around ~3GB per 30minuets.
Its a killer!
:laugh:
600gb in my pc 250gb in my portable, 80gb in my laptop for perth side.
At home in Singapore 4 pcs 200gb, 160, 120, 120. 2 laptops 40 and 60gb shared among my family.
Total of ... ermm... *math*... 1630.
Just got my pc so the 600 came with it. =)
Alpha, i heard that using SLI for graphic cards are at only about 80% efficiency ? So that means u get about 1.6x performance gain? Currently using a ASUS p5n32 SLI with the nforce4 chipset.Got an Asus 7900GT top edition in it. Thinkin of gettin another for the SLI but was thinking if it was more worth it to change the 7900GTX instead.
Honestly.. Id push the 7900GT that you have and wait untill the next wave of SLI cards.. I have a feeling we are about to see a leap in vga technology.. * Vista will be pushing that leap..
Sounds like a good plan :D Thanks !
  • 1 month later...
3x 80 gig SATA drives in a raid 0 array
120meg/s goodness ;)
EDIT: Forgot I have a 40gb 2.5 inch in a USB 2 caddy, good for sharing movies and whatnot with mates
Also got a dual core opteron running @ 2.2Ghz and a 6600 GT.
Don't have any jobs going do you alpha? I make for cheap labour :whistling:
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
