Hi all just after a bit of help or info....
My mate has had his R33 for a while now and recently has been defected for his air intake setup. He has to take it to the EPA on the 22nd to have it cleared and have no idea what needs to do to make it comply. It has an Apexi pod filter with no airbox.
We need to know, what it needs in terms of an airbox and also whether it can keep this pod filter ??
Are there any aftermarket airboxes or similar I can get to suit an Apexi pod filter ??
We just really need to know what I have to do so it will pass.
Any help or input would be much appreciated because as you can see we only have a week to get it sorted out.
***EDIT*** I AM IN NSW
HAS ANYONE IN NSW BEEN DEFECTED FOR HAVING A POD WITH NO AIRBOX ?? Thanks...
Cheers,
Trev...
Edited by trevkdx
https://www.sau.com.au/forums/topic/109729-r33-airbox-questions/
what state are you in? in vic i believe pod is illegal if you have a FMIC as only one intake mod is allowed or something like that.
pod should pass if you get a box (someone on these forums sell them, fit any pod on the market) or if you're worried buy a standard airbox or borrow one to get the defect cleared.
also try doing a search on this topic should be some helpful info around. cheers.
Why dont you ring the EPA?
I mean, logic would have it that if they are testing you... you have to meet the requirements they test for...
Wouldnt they know what the requirements are?
:P
You must either have the pod in a fully enclosed box and duct air in, or have the stock airbox on the car. Since the aftermarket one then replicates the design of the stock one, just with better components.
Where abouts in NSW are you?
Me and another guy on here are making up box designs at the moment. PM me for more info if you want it.
I think it just needs to be in a box, unique autosports in sydney sell air box's for skylines with pod filters. Or you can make your own with some tin snips and a street sign!! Just make sure the writing of the signs on the inside of the box...
unifilter make an awesome airbox.
although its a complete set IIRC - as in pod and box.
borrow someones stock airbox for the day - or even buy a stock one from these forums, couldbe a few for sale, search :P
Yeah i bought one of Maxx's CAI boxes i was impressed with the work done.
made from aluminium and has perspecs top and i just use the factory air scoop.
Not exactly sure if it would pass the EPA tests. I agree with calling them to find out what the go is.
Best of luck dude.
The UAS ones look good, but aren't much good in the way of passing EPA regulations.
Mainly due to the fact that they aren't completely sealed.
A mate made a replica of one for me and after a run in with a lovely officer, he informed me of what it needed to be. I also checked alot of regulations as well to make sure I was getting the right info before I went changing anything.
I must add as well that mine was one of the old UAS ones that were made for a stock cooler, so had more holes then FMIC ones.
When I got done for my pod, what i did was got some aluminium, made two sides and a lid and bolted it to the car.
I managed to pass with that. I must admit i was really surprised as it looked really really shonky.
The epa guys/gals might be a tad more strict with the way they pass things. Good luck with that.
When the cop pulled me over and told me to pop my bonnet, he point to the metallic pod filter in my car and said that i would have to get rid of that as it was illegal to have it in there.
I asked him why it was illegal and his reply was, "because in the engine bay, temperatures get really really high and pod filters have a tendancy to catch fire and explode or something".
He said afterwards, " i dont want to be the one that gets called out to the scene because my car caught on fire and exploded because of the pod filter..." :thumbsup:
what?
what crap?
The whole reason you can't have an open filter of any sort is because it would be taking in heat and gasses expelled within your engine bay, thus creating more out the back end due to poor induction.
Or at least thats how I read it.
Hence why and stock air filter, in any type of car, will have an intake from outside the car.
when i bought my car, it had a pod fitted and i was defected(nice 2hours after buying the dam thing) and he said it changed emmissions...but im not running a map sensor not afm...
all i did was go and have it engineered and now its fine...not in a box(altho im getting one to reduce heat soak) havnt bn pulled over yet so not sure how that route would go... wasnt cheap but i was having some other mods done anyway
having the induction noise is the whole point of getting the pod filter.. pefromance wise i find it wouldnt be any better than the standard box running a k&n panel filter
I'm still really undecided on if this is true.
The problem I have with the standard box is the inlet funnel just seems too damn small to do any good
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
